Old 12-15-2004, 10:43 AM
Eric HYland Eric HYland is offline
Throttle body or fuel pump?
I found out the other day that my K5 wasn't getting gas to to the throttle body. I replaced the fuel filter and one of the lines and that didn't end up helping. I'm goin to try and replace the sending unit along with the pump while i have the tank down. If that doesn't work, then what else could the problem be? now i'm getting frustrated. and i need help. Could it be the throttle body or something electrical. Any ideas are greatly appreciated. thank you
eric hyland
Old 12-15-2004, 03:07 PM
BlazerLT's Avatar
BlazerLT BlazerLT is offline
AF -Advisor
Re: Throttle body or fuel pump?
Do a fuel pressure test before you change out parts.
Are you saying you are getting not fuel out the TB injectors when running?
1995 Factory Blazer Service Manual for sale, PM if interested.
Old 12-15-2004, 04:03 PM
When i try start the engine there is no fuel coming out of the injectors
how do i perform a pressure test?
Old 12-15-2004, 04:05 PM
upon messing around with things i noticed that there isn't power going to the fuel pump or sending unit. Is hard-wiring the pump to the fuse box advisable?
Old 12-15-2004, 04:14 PM
BlazerLT's Avatar
AF -Advisor
Don't start fucking around with the fuel pump wiring, you are looking for a fire.
Remove the inlet line to the fuel filter and see if fuel comes out when you prime the pump.
