Idles high and low in freezing temps
Hello guys I reside in Birmingham Alabama we have had an unusually cold couple mornings that my 96 Lesabre just doesnt like. I have noticed that the car starts with no problems but you can hear the idle kinds of going up and down. When i put the car in reverse this am it almost ran away with me. My mileage is right at 90,000. I also have had somewhat of a loss of power during acceleration while cruising down the interstate. Any ideas, I have replaced the following with AC delco parts
EGR valve Upper intake map sensor cam sensor plugs and wires all coil packs air temp sensor coolant temp sensor Fuel filter all vac lines Vac brake booster No ck engine lights what so ever. Could it be a failing fuel pump? |
Re: Idles high and low in freezing temps
Idle Aair Control valve, or Mass Airflow Sensor would be my guess. Pour some kerosene into the gas tank (about a gallon) and make sure you put the cap on tighly (some newer cars than mine need the cap to be on nice and tight). The kerosene will clean the injectors.
1986 LeSabre Limited L67 sleeper ![]() Fully ported & polished, shift kit, CAI, F41 polyurethane suspension, headers & 3" exhuast, |
Re: Re: Idles high and low in freezing temps
