ok let me ask u guyz something i got a 91 dx hatch an i baught a d16y5 engine also baught a si tranny will my dx axles fit cuz the guy whos doin the swap said yes an also how does this sound use my old dizzy an mani for now im goin to do the mfi swap later an should i wire up v-tec right now to a tockle untill i get a p28 ecu an obd1 obd0 harness is that safe?
you are better off doing all the work at the same time, and I wouldn't use a toggle switch for the VTEC either.
Re: ok need help
dont run VTEC with DPFI, please. its a waste of time, and the only way to make it possible is the wrong way, by using an RPM activated switch or, 'shudder', a toggle switch.
just do it right, and convert to MPFI. it doesnt help to open your valves more and for a longer duration (which is what VTEC does) if there isnt enough gas to mix with the air (which it wont get if you are using 2 injectors for 4 cylinders)
over 10 grand in parts, and about 300 hours of labor, and i only spent 3k. and then Katrina filled it with mud. |
Re: ok need help
i agree, save the headaches and do it all right the first time.
Name: Scott Stable Of Cars I have Owned: 1991 Honda CRX 1990 Oldsmobile Cutlass Supreme 2003 Honda Accord 1998 Chrysler Concorde 2007 Honda Civic 1997 Toyota Camry 1995 Saturn SC2 1996 Ford Taurus 1991 GMC Sierra 2002 Daewoo Leganza 1999 Dodge Ram 2007 Honda CR-V 2003 BMW 325i |
Re: ok need help
d16y5? Is that the eco vtec? and aren't the y series all obd2? Sounds like you are going to make it more of a headache by not doing it the right way first.
Saturn Stealership Technician #331 |
according to www.ardperformance.com
you will need si axles anytime your doing a engine swap into a dx with any engine other than a dx engine |
Re: ok need help
Nope Ur Wrong Allready Finished The Swap The Dx Axles Were Fine
