Old 12-15-2004, 08:50 AM
Skycity_BMW's Avatar
Skycity_BMW Skycity_BMW is offline
Send a message via Yahoo to Skycity_BMW
Question 97 Cavalier rear defog light problem . . . .
the rear defog worked over the weekend and then it started to snow on Monday and that's when it quit working . . . . Checked fuse in fuse box . . checked the elements in back . . No power . . .
Where do I go from here . . . PLEASE help . . . I hate winter ! ! ! !
Thanks ! ! !
Old 12-15-2004, 11:51 AM
Classicrocjunkie's Avatar
Classicrocjunkie Classicrocjunkie is offline
Lifted GMT-360!
Send a message via AIM to Classicrocjunkie
Re: 97 Cavalier rear defog light problem . . . .
Check the connection to the plugs on the rear window. Take them off and put them back on again.. Does the little amber light come one when you puch the button?
o0o0o0o... pretty beemers in your sig...
Please don't PM me with your J-body Issues. Post appropriately in the forums,
and I will toss my opinion in your thread if I have anything to help. - Thanks!
2006 Chevrolet Trailblazer
2010 Glastron GT 205XL
Old 12-16-2004, 02:16 PM
yes . . . it lights up when I try to use it . . .
and yes. . . tried the removal and plugged back in . . checked for power to elements . . . no power
thanks . . . that's from Bimmerfest 2003
Old 12-21-2004, 02:07 PM
Help . . .bump . . .
Old 12-21-2004, 02:14 PM
Lifted GMT-360!
Have you done any work in the car like puttin new speakers in the rear?.. Somthing could have been pinched or ungrounded somewhere along the way. Its hard to say.. This is one of those pain in the ass things that your going to have to start from the back and work your way following the wires and see WTF is wrong... if its not the fuse, connections onto the filiment.. there is really no other way..
Old 12-21-2004, 02:15 PM
Mangoamerican Mangoamerican is offline
Send a message via ICQ to Mangoamerican Send a message via Yahoo to Mangoamerican
check the connection on the back of the fuse and the wire to the defogger, maybe the connection in the back of the defogger.. every wire from the battery to the defroster should have some power when that junk is on
Old 12-21-2004, 05:16 PM
noshun's Avatar
noshun noshun is offline
when you swith it on at idle do the engine revs suddenly drop slightly from the extra draw on the alternator, if so all connections must be fine as it's getting juice. If not then break in the circuit. If it's particularly cold there could even be condensation in the conector at the rear screen or some light corrosion, try spraying a water dispersant like WD40 on the conection (this wont short anything) and that may help.
Red Z24 = Dead, 03 2 door = 15.5 with no traction. low 15's here i come
'Never forget Grasshopper, Not speed, smile!'
Old 01-03-2005, 02:41 PM
Did no work at all . . just quit workin . . .
even the WD 40 thing didn't help . . .
Old 01-05-2005, 04:28 PM
Bump . . it's winter time and a Beotch to see
Old 01-07-2005, 03:47 PM
nothing . . bump
Old 01-12-2006, 11:06 AM
Zingo67 Zingo67 is offline
I just had my 2003 Cavalier in for an oil change and mentioned the exact same problem you are having, and they suggested a faulty wire under the driver side dashboard near the floor. It was suggested that the heat from the heater may have damaged the wire. Upon inspection there was a wire with some damage and after replacing this section of wire, my rear defogger started working again. I hope this helps.
Paul Wight
Thanks ! ! !
