Go Back   Automotive Forums Car Chat > Nissan > Nissan Cefiro | Nissan Maxima | Infiniti I30 | Infiniti I35
Nissan Cefiro | Nissan Maxima | Infiniti I30 | Infiniti I35 Excellent platform and the good ol' VQ30DE and VQ35DE engines.
Old 12-15-2004, 07:40 AM
creyna01 creyna01 is offline
Question Lifters - possible to only replace 2 or 3?
For a 93 Maxima, is it possible to replace 2 or 3 lifters? Or do all 24 need to be replaced?
Carlos
Old 12-15-2004, 02:14 PM
Nahkapohjola's Avatar
Nahkapohjola Nahkapohjola is offline
Re: Lifters - possible to only replace 2 or 3?
Carlos
If your problem is sound, the lifters might be just tuck. Someone said the other day that using some scum removal oil additive took his VGE noise off. Try that first, clicking noise itself [if lifters] is not dangerous.
The valves are in two cylinder blocks, one at a time is opened. I really do not know, but I suspect you can change one at a time. But is it feasible? All worn parts should be replaced as necessary; go to Nissan shop for evaluation [that should be free], decide later after a second opinion somewhere else.
Old 12-16-2004, 08:55 AM
Re: Re: Lifters - possible to only replace 2 or 3?
Yes, the problem is indeed noise (a ticking sound). I think I found the 2 or 3 that are bad, but my mechanic suggested replacing all 24!! and its pretty expensive. Have you heard of this tickin noise problem before? You say its not dangerous - can you explain more? Thanks
Old 12-17-2004, 01:30 AM
Valve clicking comes from too wide valve clearance. This means valves do not open enough. The danger is that the valves do not close [opposite] and hot gases burn the sealing edges. Only power loss, maybe in the long run some abnormal wear.
...scum removal oil additive ... Try that first.
Old 12-17-2004, 11:46 AM
infinman infinman is offline
Don't forget that two metals hammering each other definately causes damage{mushrooming of both components}.DONOT ignore any metal to metal sounds coming from your engine.If it is the lifters , change all or you will be chasing them one by one.very expensive on labour this way.
