Old 12-15-2004, 12:41 AM
JGrant702 JGrant702 is offline
problem with my sunroof
I have a 1996 Eclipse RS with a power sunroof. About a year ago someone pried oped the sunroof to steal my stereo system. Ever since then my sunroof will not open. I have replace both the motor and the switch. When I use a voltage tester it is not reflecting that power is being sent to the motor when I activate the switch. DOes anybody know if there is a relay in the car that may have been destroyed when the sunroof was pried open? thanks
Old 12-15-2004, 05:18 AM
xavier3jr's Avatar
xavier3jr xavier3jr is offline
Send a message via AIM to xavier3jr Send a message via MSN to xavier3jr
kind of a stupuid question but did u check the fuse for the sunroof?
is there a short in one of the wires??
could be a number of things
96 GS - 5 Speed-Sold
1998 Ford F-150 XLT 4X4
Old 12-15-2004, 11:56 AM
Re: problem with my sunroof
I checked the fuses and none of them were blown. I can't see where any of the wires were damaged. I suspect it has a relay because wires for the switch go down under the dash and then heavier power cables are connected to the motor. The only problem is I can't get the dealer to say for sure whether there is a relay or not. I don't have much confidence in them because they told me I didn't have a starter relay either, although I was looking directly at it.
