Old 12-15-2004, 01:20 AM
CoreyD CoreyD is offline
Amp and door speakers
i Have two questions, 1 , ive had my amp hooked up for about a year, and i went to tighten sum shit, when i tightened this 1 certain screw, sparks flew! It stopped working for about two secinds then came back on is this normal? what should i do? The second qustion is how should rewire my front right door speaker it cuts in and out when go over bumps and shit thanks for the help.
Old 12-15-2004, 01:44 AM
CivicSpoon's Avatar
CivicSpoon CivicSpoon is offline
There is no Spoon
Re: Amp and door speakers
If sparks flew then you were probably pretty close to either blowing your amp or a fuse (probably the more likely thing that would happen). It's definently not a normal thing to happen, but it does happen. With speakers, just take off the panel and speaker and see if there is a short in the wire contacting the speaker. I've seen this happen in a lot of Hondas. Is it the stock speaker or an aftermarket one? And how old is it?
Old 12-15-2004, 02:42 AM
Miataracer's Avatar
Miataracer Miataracer is offline
Send a message via AIM to Miataracer Send a message via Yahoo to Miataracer
Def. check to make sure that whatever wires are around the screw you were tightening don't have a short. If you touched a screw and sparks flew that means that the whole metal panel that screw is connected to probably has power flowing through it.
LS1 RX-7 Zoom Zoom
Old 12-15-2004, 04:54 PM
Heist Heist is offline
hey corey,
where is your amp earthed? i cant seem to find a good spot. also for everyone, my headunit is not bolted in, so i can just slide it in and out if i need too.... would that cause noises going to my amps? cos i can hear the cd player through the speakers
Old 12-15-2004, 11:32 PM
Re: Re: Amp and door speakers
there alpines and they came with the car so i dont kno how how there are
Old 12-15-2004, 11:34 PM
its mounted on the floor of the trunk and my head unit isnt bolted ion euther i take it out with a flathead it makes a small noise when i turn the volume up
Old 12-16-2004, 10:55 AM
crxlvr's Avatar
crxlvr crxlvr is offline
Slowest Automatic Civic
Send a message via AIM to crxlvr
the noises you guys are hearing is likely amp whine, meaning that your ground wires from your amp is not grounded well enough, or its too damn long. another problem causing this, is if you ran your battery wire and your RCA wires next too each other when wiring the amp. this causes "noise" over your speakers as well.
Stable Of Cars I have Owned:
1991 Honda CRX
1990 Oldsmobile Cutlass Supreme
2003 Honda Accord
1998 Chrysler Concorde
2007 Honda Civic
1997 Toyota Camry
1995 Saturn SC2
1996 Ford Taurus
1991 GMC Sierra
2002 Daewoo Leganza
1999 Dodge Ram
2007 Honda CR-V
2003 BMW 325i
