Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Eclipse Problem Diagnosis
Eclipse Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible.
Old 12-14-2004, 11:36 PM
skunky_2003 skunky_2003 is offline
Send a message via AIM to skunky_2003
Question coolant light
I have a 95 eagle talon ESI with 150000 miles on it now. the coolant lights comes on(the one that looks like a house)...kinda...it usually flickers under 2k RPM and after that it stays on...as long as im giving it gas. ok i checked the coolant level and it was fine. the problem just started today and its been really cold and a lil snowy(im from WV) can anyone tell me what it could be???
Old 12-15-2004, 02:04 AM
xavier3jr's Avatar
xavier3jr xavier3jr is offline
Send a message via AIM to xavier3jr Send a message via MSN to xavier3jr
when the car warms up does it still do it?
96 GS - 5 Speed-Sold
1998 Ford F-150 XLT 4X4
Old 12-16-2004, 07:42 PM
Re: coolant light
yea it does it all the time
Old 12-23-2004, 01:41 PM
Re: coolant light
anybody???
Old 12-23-2004, 02:14 PM
GSTRacerNVUS GSTRacerNVUS is offline
Re: coolant light
I'm not from up north, but I know that there are different degrees of coolants you can buy. Maybe your coolant is not resistant enough to the cold and is getting too thick.
97 Eclipse GST MT
Race Every Day Like It Will Be Your Last.
My one insignificant mod: Dump Tube - CUT
Old 12-24-2004, 01:45 AM
Re: coolant light
well i doubt thats it because it did warm up a bit and it still done it...at the same time like within a couple hours my check engine light cam on...and then i ran outta washer fluid and now my resivour(sp??) light wont shut off...and then the check engine light came on
Old 12-25-2004, 06:38 PM
spyderturbo007's Avatar
spyderturbo007 spyderturbo007 is offline
Re: coolant light
Does the car overheat??? Take it to Autozone and have the scan the check engine light and post the code.
1997 Spyder GS-T
5-Speed
EVO III 16g, DSMLink, Walboro 190 lph Fuel Pump, FIC 650cc injectors, CoolingMist 150psi Methanol Injection, Greddy EVO 2 Cat Back, 2.5" Extreme DP, 2.5" Extreme Hi-Flow Cat, Injen intake, HyperDrive C1 Street Disk & PP, HyperDrive Lightweight Flywheel, 1g BOV, RRE UICP, Home Depot MBC, AEM UEGO WBO2, Brembo Slotted rotors, Akebono Ceramic Pads
Old 12-25-2004, 09:37 PM
Re: coolant light
no it doesnt over heat...i planon takingit somewhere tomorrow after i reset the comp.
