Alternator belt sqeaking wont stop!
sohc,no a/c,
this has been a problem for a little over a month! I've replaced the alternator,3 different belts & the water pump,belt dressing, I cant get it to stop, I've went from my belt being real loose to being very tight & all the way around! It still wont stop, it only sqeaks at 2300rpm down to 2100rpm,sqwilling, when ever it drops past the rpm's, does anyone know of any tricks or home ideas I could use to try to stop this sqeaking? I was beginning to think it was somthing loose or a bolt, I've tightened all bolts & wd-40'ed somethings,still there, its not the worst problem,but when everything else is going good you have a loud sqeaking noise thats louder then your exhaust!
In the process of B00stin my D |
Re: Alternator belt sqeaking wont stop!
If you have tried loosening it, tightening it, and tried three differnt belts with belt dressing, it may be the alt itself.
i agree, and belt dressing is the absolute worst product you can use, it will actually eat through the belt over time and can cause major damage if the belt splits during operation.
Name: Scott Stable Of Cars I have Owned: 1991 Honda CRX 1990 Oldsmobile Cutlass Supreme 2003 Honda Accord 1998 Chrysler Concorde 2007 Honda Civic 1997 Toyota Camry 1995 Saturn SC2 1996 Ford Taurus 1991 GMC Sierra 2002 Daewoo Leganza 1999 Dodge Ram 2007 Honda CR-V 2003 BMW 325i |
Re: Re: Alternator belt sqeaking wont stop!
I did change the alternator
r u sure its the alt belt, maybe its the timing belt?
checked it it looked good, let me put it this way! I've actually took the belt off & it doesnt sqeak,when I put it on it sqeaks, so its the alternator belt, any suggestions?
did it start when you changed your alternator? I'm still leaning tward bad bearings or something in it.
when I had the old alternator tested it showed the regulator was bad,
when I replaced the alternator,the car did not start right up, I think the battery was just so dead, so I jumped it,started up,been running fine, thanks for helping me out on this one, its been one of my problems for a while, I was hoping someone knew somthing to do so that it could stop sqeaking, something that would make it sticking better or somthing, but a mechanic told my brother to put soap on his belt, it helps the pulley in some way,maybe sticky or somthing, has anyone heard of this? btw,my belt also sqeaks when I'm in reverse when I let off the clutch a little bit quicker then slow, & everytime my car jerks,(shifts)
I'd put my money on the fact that you probably don't have it tight enough, and the belts slipping.
I'm going out to tighten it her ein a minute, also I put some coca cola on the belt today,thats what my brother told me to do, it helps make the belt sticky, but who knows?/?
belts arnt supposed to be sticky. you should have 1/2" of slack in the middle of the widest point between pulleys.
I took the belt off,started it up
& its still sqeaking, so now I know its not the alt belt, this is very confusing & I sort of hope it'll go away somtime somehow, I may never know!
Probably the timing belt tensioner or the water pump. My bet is on the tensioner. GL
thanks for the ideas people,
I was thinking it was the timing belt for some reason, but I changed the water pump less then a month ago, because I thought that was it,but it wasnt, I never did change the timing belt, but we took it off,it looked good, we put it back on ,how would this make a sqeak? its on by grooves in the cams & water pump pulley?/ I dont c how it would make a sqeak,but if this is my only way out, I think I'ma change my timing belt sometime soon & see what happens.
the tensioner on a timing belt is usally the culprit of squeaks. and i really hope you never put soap or a can of soda on your belt, prolly ruined more than you fixed.
