| Car Audio Do you live in your car? Then you need to be able to listen to some high-quality music. |
Hey whats up I'm new to all this car audio stuff so I got a few questions. First of all i'm re-building a wreck 02 mustang and I'm building a custom fiberglass box to go in place of the back seat. I set it up to hold 3 12's and 2 10's. I already bought the 3-600 watt 12's and 2-600 watt 10's. All mtx. And 600 and 800 watt mtx amps. all totaled up to be about $17-1800. Was this a good choice or not or there 3 other 12's n 2 other 10's that are better...n also should i get a different amp. And what the hells are ohms haha.
Whats up with this amp on this site??? http://cgi.ebay.com/ws/eBayISAPI.dll...767923244&rd=1 |
Re: Need Help New To Car Audio
was this a good choice - no, both the setup and the equipment are bad choices
are there better subs - yes, a very emphatic yes should you get a different amp - well first off you should get either 1 amp or multiple identical amps, so yes ohms - http://www.automotiveforums.com/vbul...d.php?t=332169 amp on ebay - that's a home audio amp, and a very good one at that
'01 Black Sentra SE Weapon-R intake, HS header, HKS catback, ES motor mounts, B&M short shifter, Tein coilovers Alpine 9835, Adire Koda 6.1, Adire Brahma 15, Arc 2100cxl, Linear Power 2.2hv, Cadence ZRS-8 '05 Silver WRX STi Injen SES Downpipe, HKS Carbon-Ti catback, Cobb Stage 2 Tune, TiC Super Shifter, TiC Klunk Killer, Tein springs, Nitto NT555R Drag Radials |
If you were in my situation then what would you get...for say $2000. And are you sayin somethings wrong with the setup of 3 12's and 2 10's or what? Please Explain! i need help!!!
You shouldn't have different subs playing the same frequency range, especially not different sizes. Different subs will have different frequency response and phase shift characteristics, not to mention different reaction times/sounds to transients. Each speaker has its own "personality" so-to-speak when it comes to how it sounds, if you combine multiple different subs together, with them all playing the same frequency range, these will all blur together in a mess of cancellation, peaks, and weird phase issues.
If you're doing multiple subs then you need them all to be the same brand, model, and size to avoid these problems. All the wiring also has to be symmetrical (hard to come up with a word for that), basically all the subs need to be wired the same way, and if you have multiple amps they need to be the same. $2000 on just the substage? That can get you pretty damn far, how much airspace do you think you can fit back there?
Still confused
So basically what your sayin is take the shit back that I bought haha. But we already build the the box so is there anyway that it won't sound as bad because i still need to get 3 12's and 2 10's. I'm nto sure what u mean by airspace...we took out the back seats in the car and can use as much of the trunk room as needed. And the $2000 is for the combo of amps+subs. What are some you'd suggest if it was your car. I heard there are some really good internet brands that would blow away MTX for about the same price..what do you think (cuz u deffinietyly know more than me lol) Thanks
do you have AIM or nething easier to talk on?
yeah my aim is wuzup0714
I know it's gay, leave me alone, I made it in like 8th grade
since you got off I'll just post it here
I've given it a bit of thought, and here's what I've come up with (first return the MTX stuff if it's possible) 10's 2 Image Dynamics IDQ10D4's - $130 each you would want around .5 cubic feet for each of them if at all possible. amp for the 10's hifonics brutus bx500d - $140 12's 3 resonant engineering SE12 - $170 each you would want around 1cf for each of them amp for the 12's you're going to want around 1500rms at 2.67ohm, which would be around 2000rms at 2ohm. It might actually be easier to get a trio of monoblocks, each one doing around 600x1 @ 2ohm, something like a jbl bp600.1 or a PG Octane-R 8.0:1. Assume around $225 for each of the smaller ones, or around $700 for a single big one. Total cost is somewhere around $1600, plus wiring and a new battery or alternator (or both). Now the difficult part is in the tuning....this thing is going to be a nightmare to set up right. The best way that I can figure it, assuming you got everything I listed here, and the PG Octanes for the SE's, is you let the 10's handle the upper bass and since they're so close to the driver, maybe some of the midbass as well, and let the 12's handle the low bass, where the extra displacement will really help. To do this you would want to wire the IDQs in parallel/parallel to get a final load of 1ohm and attach that to the 500d. You would set the lowpass on the 500d around 100-125hz, and set the subsonic filter around 50hz. Then you would take the RE SEs, wire each one in parallel and wire them to each amp (these will all be wired individually). You would set the lowpass on each amp around 50hz, and you would probably want to set the gains on them using a multimeter to get them all the same.
Hey man hit me up on AIM rydemenmystang I have a 97 stang so it has the same trunk and I know how to make ur stang bang. Also 3 12's will not work very well. 2 ported 12's firing forward is the way to go and like sr20 stated above if you can return that MTX stuff so you can get something better. What are you looking for out of your bass? Loud as hell low n loud good overall balance and sound quality? IM me we can discuss it.
Re: Re: Need Help New To Car Audio
Re: Re: Re: Need Help New To Car Audio
If anyone wants to talk to me, you can get in touch with me via AIM @ threedd97
UNOFFICAL AUDIO BRAND RATINGS My life is composed of the worst luck known to man. Disclaimer: My knowledge of car audio is questionable, but it usually sounds great to me. '98 Grand Prix GT 4Dr '06 XXX 12" Possibly a Cadence ZRS-10 Pioneer DEH-5500MP
I'm going to ask a few questions for Stang:
$2,000 budget and this will be for a showcar Enclosure: I already have a box made out of probably partical board or mdf board with a fiberglass front with five slots for 5 subs. Should I throw this box away, decide on my subs and then build a new box according to the specifications of the subs? Should the box be fiberglass or MDF? Is fiberglass really worth my money? What if I can't change boxes and MUST use the current box I have, what can I do with it? It's not built to air volume specifications for any kind of sub or amount of subs, nor are the subs positioned properly for best sound output. Cost isn't an issue with this box. If I rebuild a new fiberglass box, could I get some info on how it should be built according to the subs suggested in this thread? Subwoofers: Are 5 subs too many? What about 3 even? Or should I just go 1 15" or 2 12"? ------------------------------------------------------------------------------------------------------------------------------------ ------------------------------------------------------------------------------------------------------------------------------------ Here are my answers to most of them: Enclosure: I don't know shit about fiberglass, so I told him to ask here. I recommended MDF. I know it's cheaper and a hell of a lot easier. Subwoofers: I told him 2 12" Brahmas or RE SE's. I also suggested 1 15" Brahma or XXX. Amplifiers: These are fairly easy to advise on. I told him with 2 12" of any of those brands above, depending on the brand, a 1500W amp such as a Cadence ZRS-8. As for the 15"s, an eD NiNE.1 for the Brahma would be fine and save money or for the XXX, the ZRS-8 or something with more power would do. As far as electrical upgrades, a yellowtop, possibly a larger alternator and that big/magic 3 wiring upgrade.
Anybody?
This guy needs some help.
can anybody give me a little help?
