Old 12-14-2004, 09:50 PM
s10blazerman4x4's Avatar
s10blazerman4x4 s10blazerman4x4 is offline
Send a message via AIM to s10blazerman4x4
Question Antifreeze leak
Ok now this is starting to piss me off first the freakin brake lines then the door lock not to mention every time you think you are ahead of the game something goes
91 s10 blazer well documented
i noticed today i have antifreeze leaking from somewhere about half way down the upper rad hose but not from the hose checked that and it was dry and tight new hose times 4 in a month/ tightened up the drain plug as that had fluid near it to this is on the side of the power steering pump no fluid leak on other side of rad so im puzzled as this as a new thermostat
Old 12-14-2004, 09:56 PM
blazes9395's Avatar
blazes9395 blazes9395 is offline
Newbie mod
Sounds like the rad is leaking, more specifically the rad end tanks. I have had the same trouble and now I have to get the rad re cored and checked. Sounds like the same thing.
Old 12-14-2004, 10:03 PM
Re: Antifreeze leak
wouldnt it be cheaper to get a rad out of the jyd for 35 bucks? i mean its a temp fix for somethin that could cost like 200 for a new one
Old 12-14-2004, 10:44 PM
blazes9395's Avatar
Newbie mod
Yeah it would be cheaper, but I don't want to really chance it. It will only cost me $120 to get it recored and pressure tested, and its as good as new. I need it to be reliable.
Old 12-15-2004, 11:59 AM
troubles789 troubles789 is offline
Re: Antifreeze leak
Buy brand new for $125 from the radiator barn with free shipping. Bought one for my 91 and getting ready to order one for my freaking leaking 93 now. Come with a lifetime warranty too.
Sounds like the plastic tank to core seal is leaking.
Old 12-15-2004, 12:01 PM
Re: Antifreeze leak
www.radiatorbarn.com that should get you to their web.
Old 12-15-2004, 01:31 PM
Re: Antifreeze leak
ill look into that ill try to get it to february because i have insurance inspection and license registration coming up in the next 2 months and well you know when your strapped your strapped but i love everyones knowledge and this looks goodd
Old 12-15-2004, 03:05 PM
BlazerLT's Avatar
BlazerLT BlazerLT is offline
AF -Advisor
Re: Antifreeze leak
Check for the leak with the engine running.
1995 Factory Blazer Service Manual for sale, PM if interested.
Old 12-15-2004, 08:05 PM
Re: Antifreeze leak
alright will do is there anything special i should do maybe have heater goin etc
Old 12-15-2004, 09:07 PM
BlazerLT's Avatar
AF -Advisor
Re: Antifreeze leak
You never said anything about the heat not working......
Old 12-15-2004, 09:11 PM
Re: Antifreeze leak
i know but would it matter if thats running its quite cold here in pa right now and i didnt know if that made a difference
Old 12-15-2004, 09:14 PM
BlazerLT's Avatar
AF -Advisor
Re: Antifreeze leak
Well, do you have heat?
Is the engine getting up to operating temerature?
Old 12-15-2004, 09:18 PM
Re: Antifreeze leak
Yes i have heat like a beast and it gets to operating temperature and all. i might have confused you by that but yeh got heat have a new core in there and i replaced the upper rad hose 4 times in september because advance autoparts ones kept on rubbing and now i have it zip tied to the pulley bracket because the new hood doesnt close right but thats besides the point
Old 12-16-2004, 01:40 PM
Re: Antifreeze leak
i checked it when it ran and it didnt leak but then when i shut it off there was fluid
Old 12-16-2004, 02:25 PM
BlazerLT's Avatar
AF -Advisor
Re: Antifreeze leak
Ok, and where again was the fluid running from?
Can you take a photo of this?
