Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Eclipse Problem Diagnosis
Eclipse Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible.
Old 12-14-2004, 08:41 PM
tsi9187 tsi9187 is offline
i fixed it now u should be able to understand
alright yea im sorry i am new at this thx for seein that. i popped my right front tire and drove about 20 ft. the tire had a hole on the back side(inside like where suspension and all that is). thx tho for tellin me that it might be the wheel barrin. ill take the tire off and try that but if anyone else thinks they know wut it is please help me out. 91 tsi fwd.
Old 12-14-2004, 10:11 PM
1stGenRocks's Avatar
1stGenRocks 1stGenRocks is offline
Send a message via AIM to 1stGenRocks
Re: idk even know wut happened
this is a perfect example of why we need some rules making people type decently. your post has almost no helpful info in it and it's all one run on sentence. use the edit button and fix your post then maybe someone will answer you
-1stGenRocks-
95 Tsi AWD: 6 bolt, DSMLink, 880's, ACT 2600, lightweight flywheel, AGX's, Dropzone springs, poly motor mounts and suspension bushings, 3 inch turboback, gus modded 1g BOV, hardpipes, drilled & slotted rotors, 17's
plans: bastard 20g, water/meth injection NO FMIC
Old 12-14-2004, 10:37 PM
97_3clipse's Avatar
97_3clipse 97_3clipse is offline
Send a message via AIM to 97_3clipse
hes new and looking for some help. give him a chance...
1998 Eagle Talon TSi AWD
6 Bolt Swap \ DSMLink V2.5 \ ACT 2100 clutch \ PTE SCM 61 \ Forge MBC@28psi \ VPE O2 Housing \ MR Downpipe \ Thermal R&D Cat-Back \ Tial 38mm WG dumping off O2 \ FMIC w\ in short route \ AFPR setup/walbro 255hp \ PTE 880cc injectors \ Crower Ti retianers \ Crower Springs \ Crower 64414 (stage 3 race) cams \ Ferrea valves \ 3.5 bar MAP \ PLX M-300 Wideband
Old 12-14-2004, 10:54 PM
nobody can help him if we dont know what the fuck hes talking about. all we know is that he popped a tire put on a new one and it makes noise
-1stGenRocks-
Old 12-15-2004, 02:08 AM
xavier3jr's Avatar
xavier3jr xavier3jr is offline
Send a message via AIM to xavier3jr Send a message via MSN to xavier3jr
front or back tire??
take ur tire off and shake ur wheel barrin if it shakes u need to replace ur wheel barrin
did u compleatly blow the tire or just pop it? how long did u ride on it when it was flat?did u let it sit on the axle or put a spar tire on tell us what you did after it poped it could possible be ur axle or wheel barrin i highly doubt its ur brakes
if it is one of ur front tires its mor then likely the wheel barrin because when the breaks push in on the rotor it will stop the wheel barrin from shakeing
96 GS - 5 Speed-Sold
1998 Ford F-150 XLT 4X4
