Old 12-14-2004, 08:12 PM
ZCIVIC 4G's Avatar
ZCIVIC 4G ZCIVIC 4G is offline
ZC misfire while hot help
Where do i start? I just replaced the head gasket, timing belt, plugs, wires and now when i start it up it runs great for about 10 min, until it gets up to temp it starts to misfire. it slowly got worst until my engine light came on. my compression is good, and there's no cylinder leakage and the timing is setup correctly but it's missing in one cylinder. when i hit the gas it just gets worse. i diden't catch the code, i turned the key off and then back on and the engine light was off. When i first installed the engine the car ran great i can't.
any suggestions?
Old 12-15-2004, 02:10 PM
91civichatch2571's Avatar
91civichatch2571 91civichatch2571 is offline
Send a message via AIM to 91civichatch2571
even though the cel turned off after restarting the car, the ecu stored the code so it will still be on there.
ZC stuff
http://dh-racing.com
http://www.thezcr.com/html/zcbook.php
http://dmoore.com/crx/zc.htm
http://www.jgenginedynamics.com/HOME%20PAGE
http://www.theoldone.com/
Old 12-15-2004, 02:56 PM
bambam89lx's Avatar
bambam89lx bambam89lx is offline
AF - Advisor
Send a message via AIM to bambam89lx
Re: ZC misfire while hot help
definitely check the code. Once the engine light comes on, it is stored in your ecu till you reset it. Check the code.
If it is misfiring, it is 99% chance related to either plugs, wires, cap, rotor, bad dizzy.....meaining ignition related. The other .01% of the time it's a fuel problem like usually filter or injectors.
I've fixed cylinder misfire codes in newer civics and integras numerous times and 2 times it's been the plugs, 2 times the wires, and one time the distributor itself.
Jumper harnesses, mpfi conversions, engine harness conversions, vtec subharnesses, etc.
The absolute lowest prices at the absolute highest quality. Trusted. Guaranteed.
Click the image above to visit our online store!
Hastings Bseries and Dseries piston ring kits (inc. ZC) - $49 shipped
Old 12-17-2004, 06:03 PM
ZCIVIC 4G's Avatar
thanks guys. i checked out my plugs and they were fine but when i started it up i could here it arcing off the valve cover inside. i wraped the wire in electric tape and know it works fine.
thanks agine
