Old 12-14-2004, 07:49 PM
liamm liamm is offline
93 blazer no start
help please; my 93 s10 blazer cranks but wont start. I have just changed fuel pump, filter, egr valve,coil,rotor also i just pulled the intake off to check for any signs of leaking and found none.Any help would be appreciated.
Old 12-14-2004, 08:12 PM
crazys182003's Avatar
crazys182003 crazys182003 is offline
Re: 93 blazer no start
this may be a stupid question but have you checked for a spark in all of your spark plugs? I only ask b/c you did not list that you changed them.
Old 12-14-2004, 08:18 PM
BlazerLT's Avatar
BlazerLT BlazerLT is offline
AF -Advisor
you changed the rotor but didn't change that distributor cap?
1995 Factory Blazer Service Manual for sale, PM if interested.
Old 12-14-2004, 08:37 PM
Re: Re: 93 blazer no start
Originally Posted by BlazerLT
you changed the rotor but didn't change that distributo cap?
yes the cap was also changed the plugs&wires were not,but i am getting spark
Old 12-14-2004, 08:39 PM
BlazerLT's Avatar
AF -Advisor
When the last time they were replaced?
Old 12-14-2004, 08:50 PM
plugs & wires were changed about 20,000 miles ago
Old 12-14-2004, 09:39 PM
blazes9395's Avatar
blazes9395 blazes9395 is offline
Newbie mod
If you are getting a spark, and you have good fuel pressure, did you check to make sure your firing order is correct?
Old 12-14-2004, 10:05 PM
BlazerLT's Avatar
AF -Advisor
Was there any clean spots in the upper plenum?
Washed golden?
Old 12-15-2004, 05:45 PM
Washed golden?
no, the plenum was nice and grimy & black with no signs of clean shiny areas on either side. also the firing order is correct
Old 12-15-2004, 05:49 PM
BlazerLT's Avatar
AF -Advisor
What fuel pressure are you seeing with the key set to on and the engine off?
Old 12-15-2004, 06:59 PM
i do not know the pressure because i dont have a gauge but i can hear the pump working when the key is turned on.the plenom showed no signs of a leaky cpi & the pump is new I give up!!!!
Old 12-15-2004, 08:47 PM
Fireplug Fireplug is offline
NEVER ASSUME A NEW PART IS GOOD. Go ahead and throw more parts at it and some day and thousands of bucks latter you might guess right.
GET THE FUEL PRESSURE READING FIRST before you waist any more money
Old 12-15-2004, 09:05 PM
BlazerLT's Avatar
AF -Advisor
Smarter words have never been said.
Assumption is the mother of all automotive fuckups.
