Old 12-14-2004, 07:45 PM
gates gates is offline
Unhappy up/down engine idle, Battery light on/off
Hi,
I have a problem with my Windstar. Not too long ago, I have my Fuel pump/filter replaced and my alternator brand new. Everything was fine. about a month ago, my battery warning light was coming on when I push the gaz pedal and when it idles down, it goes away. It also seem that my engine is slightly reving up/down when idleing. No so evident when driving the car around. I have clean my battery connection with a metal brush because it was very corroded. Any idea of what could be the problem?
Old 12-15-2004, 02:11 PM
Dngrsone's Avatar
Dngrsone Dngrsone is offline
Send a message via ICQ to Dngrsone Send a message via Yahoo to Dngrsone
Re: up/down engine idle, Battery light on/off
Wow, this is an interesting problem... usually the light goes away <i>when</i> you rev 'er up.
This sounds like something is draining too much power when you rev the engine... the only things I can think of at the moment is the ignition system or the fuel pump (because it's working harder to maintain pressure at higher speeds, maybe).
If it's an ignition system problem, then that would likely be the PCM...not a cheap part.
2003 Ford Expedition 4.6L (Dngrswife's)
2006 Kia Sedona
2008 Toyota Prius (totaled)
1997 Windstar 3.8 liter (retired)
Replaced Head Gaskets
1988 S-10 2.8 liter (retired)
Full Rebuild
