Old 12-14-2004, 07:43 PM
ace27's Avatar
ace27 ace27 is offline
Ceramic coating on headers?
Is the ceramic coating worth the xtra $$$. Does the coating keep the under temp hood as cool or cooler than stock manifolds and keep them from creating hot starters?
Old 12-15-2004, 12:01 AM
jonnyboy9012's Avatar
jonnyboy9012 jonnyboy9012 is offline
Send a message via AIM to jonnyboy9012
Well, you can get the same cooling affects from header wrap which is alot cheaper but you cant get the same looks, if you want the same performance but are on a tight budget go with the header wrap, but if you have the extra cash to shell out, go for the ceramic.
Current Cars and Specs:
1972 chevrolet nova
402 Chevy Big Block
Borg Warner 5 speed trans.
Future Mods:
Procharger super charger
NOS Carb Plate Nitrous System (150 Shot)
Hoosier pro street radials
2005 Chrysler PT Cruiser 2.4 Liter (soon to be traded for 96 TSI AWD)
Garret T04-E Turbo
"Quick Flow" Air Filter
Complete Custom Setup
6psi@219whp
URC Member #1
Old 12-15-2004, 08:35 AM
MrPbody MrPbody is offline
AF -Advisor
Re: Ceramic coating on headers?
The term "ceramic" has become a generic term for coating headers. In fact, there are several types of coatings available for headers. The most effective is the thermal coating applied by people like Jet Hot, Swain, Thermal Tech. Those are the headers that look like they've plated with aluminum. The thermal barrier is the "hot lick" (pun intended).
What Johnny says about header wrap is correct. It's an inexpensive way to lower the temp in the engine compartment. What header wap does NOT do for you, that coating does, is protect your investment from the elements. A well-coated set of headers will not rust out nearly as quickly.
