04 Tacoma knock during bumps/brake
Had my 2004 Tacoma reg. cab for 5 mths & has 5,000 miles.
I'm starting to hear a banging from under the truck whenever I hit the regular bumps in the road I travel everyday. The knocking is even worse when braking on bumps. The road has not changed. It doesn't make the truck ride different or anything. Anyone had a prob with this? Thanks |
Re: 04 Tacoma knock during bumps/brake
I have a 2004 prerunner and my truck knocks sometimes when braking?!
Grease the sirks on the drive shift, make sure the rear wheels are off the ground, that may help things
.........\\|//........ ........(@ @)........ ...o00o_O_o00o... ..Due to budget cuts.. ..the light at the end.. ...of the tunnel has... ....been turned off.... |
If you have a "mini", there are no grease fittings on the driveshaft.
Mike |
04 Tacoma knock during bumps/brack
Get the most expensive grease you can find and grease the drive shaft spline. I had the same problem in my 04 Taco (automatic) and after 4 returns to the dealship, they wanted me to get lost (not quite, but what's the different), I did grease the spline and have been very happy with it.
Le PS: apply as much grease as you can in the lower end of the shaft. |
