Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse 2000+
Old 12-14-2004, 06:27 PM
eclipseforjon eclipseforjon is offline
PLS Help! Is there a website?
Does anyone know a website to put in your radio serial # and find the code to reset? We changed the battery in the 2001 eclipse Gt and now it says CODE..........Or do I need to go to a dealer.......
Please help
Old 12-14-2004, 06:34 PM
wars1320 wars1320 is offline
i don't think there's a website for that. you'll most likely have to go to a dealer. whatever you do, don't let them charge you for the info or tell you that they have to do it themselves. they should be able to just look up the VIN number and get the code for you.
Old 12-16-2004, 01:04 PM
undeniable undeniable is offline
Hey this is your Solution. If you have the model # then call 407 291 1448 and ask for RIAN and tell him the serial # so that you can get the code for it, if not you have to pull your radio compartment out. on the bottom of it there will be two screws get that out and pull that compartment out then go ahead and look at the model # you should be able to see if just enough to jot it down. good luck. that should do it.
Old 12-16-2004, 09:39 PM
Re: PLS Help! Is there a website?
You are a life saver! I called, got the code and IT WORKS! Thanks so much for taking the time to help me!
Old 12-17-2004, 01:11 PM
Re: Re: PLS Help! Is there a website?
No problem, I was going through the same trouble yesterday lol thats why I knew. I blew my starter and had to get a new one on. I got my battery off cause I thought that was the problem but it wasnt and then I had to reset everything. I then had to find it online and called the experts and they told me where to locate my model # but im glad I was able to help. I saw your post and I didint want to leave you hanging. I actually just suscribed yesterday to tell you because I came on here to see if anyone knew but I saw your post and noone knew so I did it my self and then I just went ahead and created my log in id and everything and thought u might need it just as I did. well take care and good luck.
