Go Back   Automotive Forums Car Chat > Honda > Interior | Audio | Security
Interior | Audio | Security Tech forum to assist in Honda/Acura Interior, Audio and Security.
Old 12-14-2004, 05:51 PM
Bochella Bochella is offline
Question 2 amps installed
I've installed 2 amps in my 87 Honda prelude. One 240 watt 4 channel and one 120 watt 2 channel. I have a Pioneer Premier head unit with only 2 RC jack outputs. How do I get the 2 amps connected with 6 speakers working. ?????
Old 12-16-2004, 03:22 PM
AudioGuy93DelSol's Avatar
AudioGuy93DelSol AudioGuy93DelSol is offline
NA is Best!
Send a message via AIM to AudioGuy93DelSol
Id the head unit has two outputs and you have two amps, than where is the problem?
Oil leak? What oil leak? That puddle under the car is just sweat from all that horsepower.
"How many NASCAR passes is that worth? 500?" (Schumacher passing Raikkonen)
Emily is amazing, and she messed with my sig AGAIN!
Old 12-23-2004, 03:29 PM
klone420 klone420 is offline
Re: 2 amps installed
Does one of the amps have an output-if so connect the rca's from the HU to the amp than connect rca's from the amp with outputs to the other amp.
Old 12-23-2004, 03:30 PM
don't tell me your tryin to hook up some subs to those amps.R U?
Old 12-23-2004, 03:34 PM
CocaColaEatsPie CocaColaEatsPie is offline
Send a message via AIM to CocaColaEatsPie Send a message via Yahoo to CocaColaEatsPie
I think you guys are misunderstanding the question. He has the two amps hooked up fine, but wants to know how to hook up 6 speakers with only 2 outputs on 2 amps.
It depends what your amps put out at 2 ohms. And where the speakers are. Do you have component speakers or are there 6 real speakers. You may have to run it at 8 ohms. What kind of speakers do you have? As far as I know the prelude only has 4 speakers. I don't believe the 87 came with tweets in the dash although it may have. Are you trying to hook up subs too???? Need more info
John 3:3
Jesus answered and said to him, "Truly, truly, I say to you, unless one is born again he cannot see the kingdom of God."
