spark plug 1 and 2 differnt from 3 and 4?
AGSF-34EE**
** If a spark plug is removed for inspection, it must be reinstalled in the same cylinder. cylinders 1+2 have an "EG" suffix. Cylinders 3+4 have an "E" suffix. If a spark plug needs to be replaced, use only spark plugs with the same service part number suffix letter "EE" as shown on the engine decal. Right out of the owners manual. What is the difference and reason to use a differnt plug in 2 cylinders? I saved the original facotry plugs. #1+2 agsf34eg red top #3+4 agsf34e while top why are they colored? ***update*** called ford and they said they no longer add the two different plugs and to use AGSF34FMF4 (autozone number 4104) 3.99 each (they dont say platunm but have the blue rings around the ceramic
1999 Escort SE 2.0 ltr sohc, 5 speed - old one 1999 Escort SE 2.0 ltr sohc, auto - new one 2002 Dodge Grand Caravan sport 3.3, auto located in beautiful New England. "You know failure isn't failure If a lesson from it's learned-I guess love would not be love Without a risk of being burned" ~ Garth Brooks Last edited by chevyn0va1; 12-15-2004 at 03:19 PM. |
Re: spark plug 1 and 2 differnt from 3 and 4?
I'm not too sure, but I would take a guess that it's because the coil pack is divided into two coil's. Two plug's for every one coil.
I'm using aftermarket plug's, all 4 are the same and the car run's fine. |
DarkblueTA GT70, FMIC, Alky-water injection, Hooker Cat back, 208/230 .549/.579 121LSA Cam, forged diamond pistons/eagle rods, LS6 block, Lakewood LCAs, BMR STB/PHRB/Sway Bars, poly torque arm bushing, Spec Stage 4i clutch, B&M Ripper Shifter, SLP Subframes, 60# injectors, KYB AGX shocks/struts, Moser 12 bolt(373 gears, 33 spline axles, posi, ta girdle/etc/etc/etc) and HPTuner kit 2007 Nissan Titan Daily Driver. 2* advance
Motorcraft Platinums here, the EE is what it says to get, but there was a replacement on those at AutoZone, so I got those...and they work great. gapped to .054 all around.
