Old 12-14-2004, 03:26 PM
tonsoffuns tonsoffuns is offline
chev 350
can i fit a chevy 350 into a 2 door xj, 4cl, 2.5 and will it bolt to the transmition i curently have.
Old 12-14-2004, 06:22 PM
scuba4321's Avatar
scuba4321 scuba4321 is offline
I would say it would fit in the engine compartment, plenty of room, but with motor mount,cooling modifications as well as having to change fuel delivery, and the transmission too!
Old 12-15-2004, 08:21 PM
Re: chev 350
would i have to get a new trans?
Old 12-15-2004, 09:27 PM
MagicRat's Avatar
MagicRat MagicRat is offline
Nothing scares me anymore
Re: chev 350
scuba is correct. You will need a matching chevy transmission (automatic is much easier to install). It will fit but be prepared to fabricate just about everything, including engine and transmission mounts, drive shaft, exhaust system, wiring harness etc.
The air cleaner will be interesting, you may need to fabricate a hood scoop for clearance.
Also you will need stiffer front springs, a set from a 4.0 L six should do.
Old 12-16-2004, 12:14 PM
andrew2514 andrew2514 is offline
I had a friend that put a chev 305 in an older wrangler and it matched up with the trans pretty nice, he only had to but new mounts and fabricate a few parts, It might be easier with a 305 but not I'm not 100% sure.
Old 12-16-2004, 10:15 PM
glennco1 glennco1 is offline
Re: chev 350
Check out Advance Adapters, they make all sorts of parts for swaps like this. 305 or 350 shouldn't make a difference, they are both Chevy small blocks.
It would be a tricky install, and I would think it would tear up the drivetrain fairly quickly.
Old 12-20-2004, 01:29 PM
Re: chev 350
Thax
