Go Back   Automotive Forums Car Chat > Saturn > SC/SL/SW
Old 12-14-2004, 10:32 AM
Splitz300 Splitz300 is offline
Ects
Wondering the EASIEST way to change this sensor. Not sure if it's bad or not. I've read many things about this year/model has problems as they get older and can effect gas mileage. It's been steadily decreasing over the last 6 months. 1998 Saturn SL.
Can I change the sensor without draining coolant and can it be done in the driveway? Easiest way please!
Thanks.
Splitz300
Old 12-14-2004, 11:32 PM
sierrap615 sierrap615 is offline
Master Tech Wanna-be
Re: Ects
if you are really fast, wait until the engine is extrimely code, remove the cap to remove pressure, then put the cap back on to create a vacuum in the system, then you don't need to drain the coolent, but if you did, you would only need to drain about 2 liters.
http://www.saturnfans.com/forums/showthread.php?t=24003
