Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Eclipse Problem Diagnosis
Eclipse Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible.
Old 12-14-2004, 08:54 AM
verduccivb verduccivb is offline
1996 eclipse GST wont stay on
I have a 1996 eclipse gst that has an idleing problem. When the car is started, it will idle for about 5 seconds then it will shut off. What could be the problem?
Old 02-08-2005, 01:10 PM
speed_demon_dc17 speed_demon_dc17 is offline
Re: 1996 eclipse GST wont stay on
I have the same problem with my laser rs right now I wish you'd get an answer. Cause that would probably fix my problem too.
Old 12-30-2005, 10:28 PM
dkitty dkitty is offline
same problem here
Old 12-30-2005, 11:54 PM
inatalonIXLR8 inatalonIXLR8 is offline
Try hooking up jumper cables to another vehicle. If this works to keep it running, it's your alternater and most likely the battery will have been weakened as well.
95 Talon Tsi AWD 5spd
2.4L4G64 6bolt JE8.5EagleTorqueplatedFully ballanced-balanceshaftARP Ferrea1mm 1Ghead ported/polished HKS264/272 fidanzagears turbonetics copy polished GT3076R VbandTial38mm cometic prothane mounts SARD850 stage4 Compclutch+flywheel 3"exh Walbro255 rewired Innovate wideband O2 ForgeBOV Autronic standalone innovative wideband[url=http://img494.imageshack.us/my.php?image=talonandhelicopter5as.jpg]
Old 01-10-2006, 11:00 PM
WrecklessMM's Avatar
WrecklessMM WrecklessMM is offline
i think its your ecu. the same exact thing happend to me. could not figure it out.pick one up at the junk yard. you can always sell it on ebay or somthing. my cars battery wouldnt hold a charge. check engine light was reading about 5 things and it would idle at all. ended up changing the ecu after about 10 things.
Old 01-11-2006, 09:49 PM
How come we rarely end up finding out if any of our advice helped? I for one, would really like some more feedback.
Old 01-27-2006, 08:04 PM
I had a problem much like this that i just solved. It was so simple that i want to kick myself for not thinking of it right away.
One of the hoses above the throttle was a bit cracked, which was causing my car to stall whenever i came to a stop. All i did was cut the cracked bit off and refit it, and it works great!
just make sure you check all of your hoses before buying something expensive like an ECU. It may just turn out to be something simple, like a vaccume system leak.
