Old 03-03-2002, 04:25 PM
Max Power Max Power is offline
Covering body when spraying window frames?
When you guys paint the portions around the windows black (I'm not talking about the "glass", i mean the part on the body), what do you use keep the paint from getting onto your nicely polished body? I ask because I thought I had covered everything well enough with newspaper, but after I was done, I saw that some of the black had gotten onto the body. I hope I can polish it out, but how long should I wait before I do that? I guess I should just make sure I have everything, and I mean everything, covered up.
Old 03-03-2002, 05:18 PM
kicker1_solo's Avatar
kicker1_solo kicker1_solo is offline
Send a message via AIM to kicker1_solo Send a message via Yahoo to kicker1_solo
Make sure the paint is dry before you take the tape/newspaper off too.
2000 BMW 323IT
1954 Ford F100
With every post my penis grows smaller
Yakima Valley Truck Club Yakima Washington
Old 03-03-2002, 05:39 PM
nismo kid nismo kid is offline
Wouldn't it be easier just to paint it with a brush? That's all I do.
Rich.
Old 03-03-2002, 06:26 PM
daggerlee's Avatar
You can just use regular tape. Make sure it's not too sticky, otherwise it will peel the paint off. You gotta press around the edges with something flat and hard to make sure its completely attached to the paint.
Old 03-03-2002, 06:34 PM
primera man's Avatar
"P-Man"
Regular tape wont work as it will not seal correctly and wont leave a nice straight line. Leave's a jaggered line. It has a bad habit of bledding the paint under the tape as well.
Only use Tamiya tape as it will not bleed though and will leave a good finish.
As for masking the rest of the car.....if you spray the black you will have to take a lot more care to make sure you have everthing masked off.
If you brush it with enamal paint you can get just as good a finish if you do some nice light coats.
View All My Models Here.
I guess I should say that I was using Tamiya masking tape, but I didn't want to waste it by covering everything else with it, so I used newspaper for the rest, but I didn't cover it from the bottom. The wind must have blown the paint underneath the paper. I guess have to cover it completely. I just thought there might be an easier way to do it.
That's what I had done before. I agree it's easier, but I didn't like the results too much. It takes a lot of effort to make it straight. I think masking and using a spray gets you much cleaner results.
Old 03-03-2002, 06:39 PM
"P-Man"
OK......What i do is use 6mm tape first then overlap half of it with 10mm tape. After that i use regular tape overlayed over the 10mm tape. Then use the paper and rugular tape to mask of the rest of the model.
Yes....you need to mask underneath it to.
Old 03-03-2002, 11:20 PM
turbos86's Avatar
turbos86 turbos86 is offline
If you don't want to use so much of the expensive Tamiya tape, then just use it to mask around the edges and cover the rest of the body a plastic bags, cut to your liking
Old 03-03-2002, 11:40 PM
awaken1973 awaken1973 is offline
Send a message via ICQ to awaken1973
It's easy with brush if you cut a good groove along window lines
If you use airbrush it helps too. Groove is a must!
Current project: Tamiya Porsche 959, red
Old 03-03-2002, 11:41 PM
Old 03-04-2002, 12:19 AM
...cover the rest of the body a plastic bags...
Plastic bags! That's ingenious! I think i might try that next time.
The models I've done so far already have that groove and I'm still not satisfied with the brush results. I'm rather satisfied with what I got using masking tape and spraying it (other than the overspray, of course).
Old 03-04-2002, 03:46 AM
Jay! Jay! is offline
Horizontally Opposed
I use plastic bags, too. Usually cut-up grocery bags.
Hierarchy of Subaru:
(Click to see mine!)
