Old 12-14-2004, 03:44 AM
TanKaBoY's Avatar
TanKaBoY TanKaBoY is offline
adding a roll cage?
How do u add a roll cage to a car like the fujimi FD3S RX-7?, and what materials would u use to do it?
Completed:
Sexy Iwase Kyoko's FD3S RX-7
Apexi D1 FD3S RX-7
Old 12-14-2004, 03:57 AM
deedlit's Avatar
deedlit deedlit is offline
Re: adding a roll cage?
About the material, I would use styrene tubes or copper strings.
You heat the styrene profiles with a flame and then bend them to shape. Copper is easy to bend because you can do it without the help of any tools but must be soldered, I've never tried to glue copper, I think it won't work. There was a tutorial on BMC, I search the link.
Edit: http://www.briansmodelcars.com/tutor...D=13&CurPage=1
Old 12-14-2004, 06:42 AM
TanKaBoY's Avatar
what about super gluing the copper?
Completed:
Apexi D1 FD3S RX-7
Old 12-14-2004, 07:08 AM
sjelic's Avatar
sjelic sjelic is offline
if you try the super glue on cooper it must be a perfect joint and that is very hard to do. It is much easier to solder it, that is no problem at all and the joints will be perfect. Soldering tool is very cheap and you always need one, just buy the one with thin head with trigger switch and some soldering wire (thin) and you can do it in 20 minutes. I think that would be the easiest method by far. Just watch out for fingers because cooper is heated in seconds
Sasa Jelic
SCALEMAKERS
Old 12-14-2004, 07:34 AM
DavkeG DavkeG is offline
I think you can use putty on copper, it holds on to pretty much anything
Old 12-14-2004, 08:04 AM
TanKaBoY's Avatar
ok thanks i might borrow a soldar from friends or i might go with putty. if it works like u said.
but wont the heat from the soldar melt the plastic mold of the model?
Completed:
Apexi D1 FD3S RX-7
Old 12-14-2004, 08:19 AM
ATMDC's Avatar
ATMDC ATMDC is offline
i tried to solder copper once and it wouldnt stick?
Old 12-14-2004, 08:33 AM
TanKaBoY's Avatar
ummm i think u need to sand it down a little. I tihnk i've done something like this at school(not sure though)
Completed:
Apexi D1 FD3S RX-7
