Old 12-14-2004, 01:45 AM
Matthew12M Matthew12M is offline
valve adjustment
Hey guys, I got an 88 c1500 350 5.7
I just replaced the valve stem seals and adjusted the valves and it runs pretty good until about 20 minutes of driving. After the car has been at full temp (190 degrees) for about 10min, while waiting at a red light, the truck will idle a little rough. The rough idle will become increasingly stronger the longer i drive it. Its not enough to cut off the engine, but I can definitely feel it. It is timed at 0 degrees. Also when i replaced the seals, I used an umbrella type seal on the exhaust valve which wasn't used on the original design.(it was a recommendation) It helps reduce oil being sucked into the exhaust valve by the vacum. It drives fine after I start driving from idle. If i misajusted a valve or a few valves then why doesnt it idle badly from the start when the engine is cold? What other things besides the valves can cause this sort of problem? Please help
Thanks,
Matthew
Old 12-16-2004, 05:13 PM
kenny-1907's Avatar
kenny-1907 kenny-1907 is offline
Send a message via MSN to kenny-1907
Re: valve adjustment
Rough idle when hot/warm could be many things. Plugs/wires/cap/rotor just to name a few. I think timing being off will also affect an engine when it warms up <shrugs>
**2007 Avalanche LT. **
6" Pro Comp lift
305/55/20 BFG A/T KO'S
K&N FIPK GENII
Flo Pro V force muffler & 4" slash cut stainless tips
Color matched front and rear Bowties
3" polished stainless bull bar and Nerf bars
Old 12-16-2004, 06:47 PM
Fireplug Fireplug is offline
Vacuumk leak
