Go Back   Automotive Forums Car Chat > Ford > Mustang > Mustang Problem Diagnosis
Mustang Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible.
Old 12-14-2004, 01:10 AM
probmxer426 probmxer426 is offline
Send a message via AIM to probmxer426 Send a message via Yahoo to probmxer426
battery failure
I have a 1992 lincoln mark 7 with 175,000 miles on it. It has a 5.0 H.O. EFI mustang engine in it. Lately i have been having a problem with the battery dying. If I jump start the car I can drive it around all day, as long as I dont let it sit for a couple hours. But after it sits overnight, the battery loses the charge. I recently purchased a new Optima red top battery and I am still having the same problem. Got and ideas on what could be wrong or how i could fix it?
Old 12-14-2004, 01:32 AM
StangNut86 StangNut86 is offline
Send a message via AIM to StangNut86 Send a message via Yahoo to StangNut86
Re: battery failure
your alternator's bad. if it's not, i'll buy you a yacht in sweden loaded with nekkid swedish models.
-Andy
'89 Mustang 5.0 - How fast? i'll know this weekend.
'86 Mustang LX - Shortblock is built, now for the rest of it.
"Put the subject before the verb, hmm? Fail this class, you will."
-Yoda teaches english class.
Old 12-14-2004, 08:53 AM
andrewespo's Avatar
andrewespo andrewespo is offline
Re: Re: battery failure
Can I come?
1988 Mustang 5.0 5spd/CAI,BBK 65mm TB,BBK underdrive pulleys, Flowmaster catback, E303 cam, headers, mass air conversion, Steeda tri ax shifter, 3.73 gears, Trick Flow street intake, 3g 130 Amp Alt.
Old 12-15-2004, 04:39 PM
problem
I know that you think that it is the alternater. But i just had that replaced 1 month ago. I also purchased a new optima battery and a new selenoid. What could be causes the problem. Could it be a power short?
Old 12-15-2004, 04:59 PM
Re: battery failure
well, if you're absolutely sure you're alternator is bad (have it tested), then you have a bad electrical drain... those can be difficult to track down.
-Andy
Old 12-15-2004, 05:13 PM
andrewespo's Avatar
Re: battery failure
Try testing all the wires running from the alternator and the battery. You said the the alternator is new so maybe some one didn't connect one of the wires correctly. Basically trial and error, it's frustrating but necessary.
Old 12-18-2004, 09:54 PM
nick83stang nick83stang is offline
i had this problem and well i still do. i just disconnect the positive battery cable at night and its fine.
Old 12-19-2004, 12:12 AM
HiFlow5 0's Avatar
HiFlow5 0 HiFlow5 0 is offline
Stanger
Send a message via AIM to HiFlow5 0
Re: battery failure
Check the battery cables, make sure they are corrosion free. Also checl where the negitive cable attaches to the block, maybe give it a good cleaning.
[size=1]-1950 Ford Custom, flathead V8
-2013 Ford Flex
-1999 Ford F150
Old 12-19-2004, 01:47 AM
matt17 matt17 is offline
Re: battery failure
try replacing the plug to the alternator,ford was notorious for bad plugs,advance and zone sell replacement plugs
Old 02-08-2005, 09:55 AM
I finally found out the problem. The Alternator wasnt bad and the battery wasnt bad either. The new battery and alternater werent mixing well. The new alternator was overcharging the battery and the car still had the old voltage regulator on it, so I just got a new one and it works great now. No problems. Thank you for all of your advice.
Old 02-08-2005, 05:08 PM
Laxxplyr Laxxplyr is offline
Andy,
What kind of yacht are you buying? can you just Fed-Ex one of those models to me instead?
89 GT 5.0L (soon to be 5.4L)
01 Toyota 4Runner, Supercharged SR5
"hey kid! you wanna race that Honda?"
92 F150
Loves to get beaten on daily
This is you before a Ford -->
This is you with a Ford -->
