codes!
ok, when i checked for codes the first time, well the guy was a retard and only got 1 code, or maybe cuz there was only 1 problem! now there's 2, i got code 44 and 43
CODE 43
Trouble Code 43 indicates that there may be a malfunction in the Electronic Spark Control (ESC) circuit. ESC is used to sense spark knock (pinging) and retard the timing to eliminate it. A knock sensor (located at the rear of the engine block) sends signals to an ESC module which then signals the ECM that knocking is being detected. The ECM will retard the timing by as much as 20 degrees in 1 degree increments. A loss of knock sensor signal or loss of ground at the ESC module will cause the signal at the ECM to remain high. The ECM will act as if no knock is present, and may possibly result in engine damage, if there is detonation. Loss of the ESC signal to the ECM will cause the ECM to constantly retard the timing to its maximum. This results in sluggish performance and a Code 43. The conditions for setting this code are: Engine is running ESC input signal has been low more than 2.23 seconds Typical causes for this code include: 1) Open or shorted knock sensor 2) Loose knock sensor 3) Excessive mechanical noise within engine 4) Improper or incorrectly installed PROM or CALPACK in the ECM or defective ECM 5) Intermittent open in the EST line to the ignition module Trouble Code 44 indicates that the O2 sensor is showing a persistently high exhaust oxygen content (lean), despite the efforts of the ECM to increase injector on-time (thus increasing fuel delivered). Integrator and BLM numbers may indicate > 128 by a substantial margin. The conditions for setting this code are: no Code 33 or Code 34 (MAF Error) present, and the O2 sensor voltage remains below 250 mVolts, and the ECM is in Closed Loop control, and the above conditions exist for more than 50 seconds. Typical causes for this code include: 1) O2 sensor defective or lead shorted 2) Lean injectors (dirty or blocked) 3) Water in fuel 4) Exhaust leaks upstream of O2 sensor 5) Fuel pressure or volume too low 6) MAF/MAP sensor reading lower airflow than is actually present 7) Vacuum leaks 8) Incorrect or poorly calibrated PROM
Grand National. Going fast with class. Voted FASTEST street car on AF. Here is the proof!!! 1987 Buick Grand National. Back in action!!!! 1999 Ford F-250 Tow rig from hell 598 Ft-lbs. ASE Certified in... Mobile AC On Highway medium duty diesel engines. Off highwayy medium duty diesel engines. On highway trucks. Working on the eletronics certification Member ofA.A.N.B.C- Afer against non boosted crews #2 |
Re: codes!
he's good...
*Better power-to-weight ratio than a C6 corvette* |
Re: codes!
thanks hypsi, now, to get it fixed, this sux ballz
Re: codes!
HOLY FUCK
im pissed, i just replaced my ESC Module, and my MAP Sensor. cost me almost 100 bux and STILL its being a bitch, i replaced broken hoses so no vacuum leaks, well she's still reading up code 33, could it be my computer? |
