Go Back   Automotive Forums Car Chat > Geo > Tracker
Old 12-13-2004, 10:44 PM
cskarnes cskarnes is offline
Tracker Won't Start
I have a 91 Geo Tracker. The engine turns over freely, and will start when I spray starting fluid in it. It will only run shortly until it burns of the fluid. The fuel pump relay under the dash is buzzing, so I replaced it. However, I now noticed that there is a clicking noise from the throttle body as well? Is there another relay, or what is causing this? Thanks.
Old 12-22-2004, 06:07 PM
Rutteger Rutteger is offline
My '94 Tracker is having the same problem, and is going ot the dealer tomorrow to find out what is wrong with it.. my local mechanic couldn't find the problem. I'll let you know what the problem is then!
Old 12-24-2004, 09:29 PM
Rivernet1 Rivernet1 is offline
Send a message via ICQ to Rivernet1 Send a message via AIM to Rivernet1 Send a message via MSN to Rivernet1 Send a message via Yahoo to Rivernet1
Re: Tracker Won't Start
Did you check the line and/or fuel filter?
Old 01-13-2005, 02:13 PM
rruddfan21 rruddfan21 is offline
is the fuel injector squirting fuel? fuel may be reaching it, but it may not be opening to spray out fuel.
Old 11-02-2005, 01:57 PM
baumbr baumbr is offline
You're in luck - you have one of the model years with sub-quality Mitsubishi produced ECM's. Before you dump a bunch of money on a lot of parts have the ECM checked by a shop that specializes in them. A computer code reader won't tell you whether its bad, it has to be checked by a specialty shop. Good luck
