Go Back   Automotive Forums Car Chat > Volkswagen > Passat
Old 12-13-2004, 08:56 PM
HEYOCHOA HEYOCHOA is offline
Unhappy Throtle Body Problems
I HAVE A '96 PASSATT WITH AN ENGINE LIGHT ON. TOOK IT TO HAVE IT SCANED RESULTS ARE THAT THE THROTLE POSITION SENSOR ON THE THROTLE BODY HAS FAILED.. NEEDLESS TO SAY THAT THE TPS SENSOR IS NOT SOLD SEPARATLY FROM THE THROTLE BODY, AT A COST OF $376. DLS.. IS THERE ANYONE OUT THAT COULD HELP ME FIND ONE THAT IS USED OR REFURBISHED OR ARE THESE PART ADJUSTABLE
THANKS
TONY
Old 01-09-2005, 01:07 PM
swipter swipter is offline
I don't know if I would buy a used sensor. You may get into the same problem you have now. Have you tried sensor cleaner?
Old 01-09-2005, 01:15 PM
Re: Throtle Body Problems
Would it be possible to change the throttle body to an updated one that has a replaceable TPS? I found sensors for later years without the entire unit.
Old 01-17-2005, 11:25 PM
veedubmechanic's Avatar
veedubmechanic veedubmechanic is offline
VDUBMAN
VW sells A throttle body because the TPS is integrated into the throttle body itself.
