Old 12-13-2004, 07:33 PM
LT-Z71drvr LT-Z71drvr is offline
More exhaust questions...
On my 96 2500 truck, it has the dual inlet muffler. I plan on removing the stock exhaust right before the muffler and running duals with 90's out the sides.
My question is, after removing the muffler and tailpipe, will I need a
balancer tube between the dual pipes? I have it figured out how I can
fit the H pipe in and install two really short glasspacks behind it. But, I dont know if glasspacks are what I want or not.
Otherwise, what is a good CHEAP dual in/dual out muffler? Everything I have found is right up there around $100.00 or more.
Please help!!
Thanks.
1996 K2500 Reg Cab Long Box
5.7 Vortec, HD 5-speed manual (NV4500)
LT265/75R16E Toyo Open Country M/T
Hypertech Power Programming (AWESOME)
K&N Air Filter, Flowmaster Exhaust
Centerforce Dual Friction Clutch
Pioneer Head Unit, MTX 200 Watt Amp, MTX 10" Thunder 4500 sub
"To be old and wise you must first be young and stupid"
Old 12-13-2004, 10:22 PM
abaird abaird is offline
Re: More exhaust questions...
Well first i will tell you what i have. I had the same dual inlet muffler on my 97 z71. I had it removed and from there I ran 2 1/2" duals out the back through 4"x18" tips. I get comments all the time on how it sounds and it is extremely loud and deep which is what i was looking for at the time. I would recomend this instead of glasspacks. It still will cackle nicely if that is what you want. However if I was going to do it again i would use a balance pipe, i hear it will make the sound a little smoother and it is supposed to give you the most power from dual exhaust.
About the cheap mufflers, go to ebay and you can get new flowmasters for a good price. Hope i helped.
2009 Silverado 1500
2002 Camaro Z28(rebuilder)
2005 Yamaha GP1300R
Old 12-15-2004, 12:44 PM
bmauws bmauws is offline
I've got a 97 with dual glass packs, 2 1/4" tail pipes and 3" tips, the glass packs have gotten really worn in and it has a rumble down low, but when you open it up it turns into a real nice cackle. If you do go with glass packs get good ones the cheap ones burn out and fall apart to quickly.
Old 12-15-2004, 02:55 PM
Silverado Brethern's Avatar
Silverado Brethern Silverado Brethern is offline
On my 97 i sawed the muffler off welded two flowmaster 40 series delta flow's on, then two 90's and two pieces running out in front of the tire. If you get a muffler i would recomend an origional 40 series cuz they are a lil deeper and remember, if it's cheap it will sound cheap. i did mine by myself and it cost around $210. oh and i wouldnt bother with a balancer pipe.
"Never under estimate the power of stupid people in large groups."
1997 K-1500 Silverado Vortec 350...125,610 and wounded
HD chassis package
Custom TRUE DUAL exhaust with cut-outs and Flowmaster 40 series mufflers
Poweraid Throttle Body Spacer
Custom Ram-air Intake with K&N FIPK GEN II
TFES Performance 3" Suspension Lift
Dual Air-Horn Kit with Compressor
Bed-Mounted 48" Hi-Lift Jack
Cobra Laser Radar Detector
285/75/R16 Cooper Discoverer STT's
1/4 Mile 10/15/05: 16.43 @ 91mph
Old 12-16-2004, 02:37 PM
cdoogles cdoogles is offline
What year/models did they start using the dual inlet muffler? my 1993 k1500 has a single in dual out magnaflow muffler that I've been pretty happy with, but I wouldn't mind switching to dual all the way back. I wonder if the stock exhaust manifolds would bolt onto the engine and fit alright. I have very limited welding experience so I wouldn't want to jump in over my head, but replacing manifolds and a new muffler I can handle.
Old 12-20-2004, 09:23 PM
Re: Re: More exhaust questions...
Do the 40's produce a lot of resonance in the cab??
I hear ya about the cheap/sound cheap thing.
I am thinking of just installing the system as it comes, but instead of straight out the back I would put 45's on it. I dont want straight out the back cuz EVERYBODY has that around here!!
Old 12-21-2004, 11:08 AM
BIG Z71 BIG Z71 is offline
I run straight pipes out off the cat's with the big chrome tips (boom tubes) out the back. I get so many people follow me around till i stop just so they can ask how i got my truck to sound like that..LOL.
sounds good! was one of the first trucks aroun like that now every one is doing it.
