Old 12-13-2004, 07:22 PM
95 cyclone 95 cyclone is offline
1st gen jdm in 2nd gen ????????'s
im swaping out my 95 crankwalked 4g63 w/ a 1st gen jdm.
is everything pretty much the same? i got the motor all built ready to throw in but i only have 3 days at the shop to do it. i need to know what i have to replace or what i need to buy to get the thing going. ive done lots of turbo work but never really swapped the whole motor out. i have all the wiring, injectors, ecu, turbo, all the works. help me out if you have done this swap.
Old 12-13-2004, 09:24 PM
1stGenRocks's Avatar
1stGenRocks 1stGenRocks is offline
Send a message via AIM to 1stGenRocks
Re: 1st gen jdm in 2nd gen ????????'s
check vfaq.com they have a bunch of info on putting a 6bolt in a 2G. im not sure what all is different on a jdm motor but that should get you started. i think all the jdm 1G's came with 16g turbo btw
-1stGenRocks-
95 Tsi AWD: 6 bolt, DSMLink, 880's, ACT 2600, lightweight flywheel, AGX's, Dropzone springs, poly motor mounts and suspension bushings, 3 inch turboback, gus modded 1g BOV, hardpipes, drilled & slotted rotors, 17's
plans: bastard 20g, water/meth injection NO FMIC
Old 12-14-2004, 09:57 AM
LandoAWD LandoAWD is offline
Send a message via AIM to LandoAWD
Re: Re: 1st gen jdm in 2nd gen ????????'s
Only the ones from the Galant with the "yellow top" 510cc injectors.
Kris
2012 Genesis Coupe 2.0t
