Go Back   Automotive Forums Car Chat > Racing > Street Racing
Old 12-13-2004, 07:13 PM
turbo2nr's Avatar
turbo2nr turbo2nr is offline
Send a message via AIM to turbo2nr
Talking your end of the year goals!
ok so the year is comming to a end quickly,
so i was just curious how did evey one do one their yearly goal for their car?
meaning did you guys accomplish what you set out to do to your car for this year?
i myself exceeded that goal, i was just planing to get the probe up and running and do the intake/exhaust/ mbc@12psi, i got way past that, i wasnt expecting the probe to become this quick in this period of time. so im happy with my progress during this year
im such a ..
next year goals:
get a faster car! 13sec car by the end of next yr. thats my goal. i hope i can get there and excede it by next yr. end.
1
Shift_BOOST
97 s14
Old 12-13-2004, 07:15 PM
drftk1d's Avatar
drftk1d drftk1d is offline
boost in, apex seals out
Send a message via AIM to drftk1d
Re: your end of the year goals!
I just got my car this year so...
i guess for next year i'd like to swap to turbo engine.
RX-7 TII
Old 12-13-2004, 07:19 PM
HighRev87's Avatar
HighRev87 HighRev87 is offline
Banned
Re: Re: your end of the year goals!
My goal of the year was to mod a crappy 4door sunfire into a Mustang GT. Funny, it actually worked out, but I cheated....alil.
Old 12-13-2004, 07:21 PM
jonnyboy9012's Avatar
jonnyboy9012 jonnyboy9012 is offline
Send a message via AIM to jonnyboy9012
Well, i got the 396 into the nova, but it really wasnt a goal at the start of the year. It just kinda happened, but yes im very happy with it.
Current Cars and Specs:
1972 chevrolet nova
402 Chevy Big Block
Borg Warner 5 speed trans.
Future Mods:
Procharger super charger
NOS Carb Plate Nitrous System (150 Shot)
Hoosier pro street radials
2005 Chrysler PT Cruiser 2.4 Liter (soon to be traded for 96 TSI AWD)
Garret T04-E Turbo
"Quick Flow" Air Filter
Complete Custom Setup
6psi@219whp
URC Member #1
Old 12-13-2004, 07:28 PM
beyondloadedSE's Avatar
beyondloadedSE beyondloadedSE is offline
AF Ford Contour-Advisor
300 whp, 321 wtq @ 8 psi. Should put down 400 whp on 15-17 psi and some higher octane gas. Guess we'll find out after the new year.
"The CEG Nazi"
www.contour.org
1996 Ford Contour SE - Sold
3.0L V6 and Arizona Dyno Chip Turbo Kit
364 whp, 410 wtq @ 16 psi and only 4,700 rpms.
1999 Tropic Green SVT Contour - Bone stock and MINT
Old 12-13-2004, 07:41 PM
Amish_kid's Avatar
Amish_kid Amish_kid is offline
b16a sir1 swap, and by the end of next summer a t3/t4 hybrid running 7-8psi
Old 12-13-2004, 07:45 PM
turbo2nr's Avatar
beyondloadse did you do all that work to your contour? can you give some specs? im assuming its the sho motor..
thaks
Shift_BOOST
97 s14
Old 12-13-2004, 07:48 PM
Igovert500's Avatar
blue + red light magnet
Nope,
the goal was 400hp at the crank this summer...wont happen until Christmas
and Turbo/fuel system upgrades by Nov....that wont happen until next July at the very least...
if only turbos grew on trees....
96 3000gt vr4
-K&N FIPK
-Proboost mbc
-Greddy type-s
-ATR downpipe
-no cats
Old 12-13-2004, 07:56 PM
-Josh-'s Avatar
-Josh- -Josh- is offline
Automotive love doctor
Send a message via AIM to -Josh-
Some of it..
1) Get body panels back on Buick- Check
2) Get Buick painted- Nope
3) Get Buick Running tip top- Kinda sorta
4) L67 Swap in Buick- Maybe next year
5) Supercharge the Maro- Next summer
Self improvement is masturbation
AF User Guidelines
What is a mippie? - click
Old 12-13-2004, 08:00 PM
CamaroSSBoy346's Avatar
CamaroSSBoy346 CamaroSSBoy346 is offline
Send a message via AIM to CamaroSSBoy346
I'm not sure If i met my goal yet. My goal is to beat, atleast, a stock 99+ Mustang GT (In the T-Bird). No goals for the Camaro, becuase its staying stock.
2002 F150 SuperCab FX4 6" Fabtech, 3" BL, Detroit locker, Edge tuned, Yukon 4.56s, 37" Nittos, Harley lights, Depo fogs, 8K HIDs, Powerstop brakes
1992 Lincoln Mark VII LSC 302 H.O, A9L ECU swap, 65mm TB, 73mm Granetelli MAF, FRPP 30lb injectors, Walbro 255, MSD ignition, Powerdyne BD11 supercharger, Efans, T-5 swap w/ FRPP flywheel, Ram HDX clutch and adjustable Steeda clutch quadrant, 4.10 gears, Nitto NT555R radials
2000 OBS Tahoe Z71 6k HIDs, 33" Goodyears. 280k mile daily beater
Old 12-13-2004, 08:20 PM
Re: Re: Re: your end of the year goals!
thaks
Nope, Its a 3.0L duratec out of a Taurus. Its the same motor as the 2.5L duratec but its .5L bigger. Pretty much a straight swap. Heres a quick cut and paste from my cardomain page.
1999 3.0L 24V Duratec longblock
Forged Aluminum Ross Racing 8.5:1 pistons
Forged 4340 Chromoly Pauter Connecting Rods
1mm overbore and balanced crank
Clevite 77 and Federal Mogul bearings
Arizona Dyno Kit Kit
-Garrett T3/TO4E ball bearing turbo
-Spearco 700 cfm Water/Air intercooler
-321 Stainless steel turbo manifolds and collector pipe
-Custom burned chip
-42lb injectors
-Water resevoir and pump
Walbro 255lph fuel pump
Ported and polished 3.0L heads (3 angle intake, 4 angle exhaust)
Mondeo ST220 3.0L valve springs
2000 SVT lower intake manifold
BAT Electric Waterpump and controller
3.0L Valve covers
Custom 3" Mandrel Bent Magnaflow Exhaust
Dual mode dampener
Bulldog Box Transmission
-Quaife LSD
-Zetec 3.82 final drive ratio
-Post 2000 shifter forks
-All new bearings
Fidanza 11.5lb Flywheel
SPEC Stage III clutch
Driveshaft Shop Stage 2 axle shafts
SVT front and rear motor mounts
Energy Suspension polyeurathane inserts
Apexi AVC-R boost controller
Ford Lightning 80mm MAF
Lotek gauge pod
Autometer mechanical boost gauge
Autometer electrical oil pressure gauge
Autometer electrical EGT gauge
1500 degree 100' x 2" header wrap
"The CEG Nazi"
www.contour.org
Old 12-13-2004, 08:23 PM
turbo2nr's Avatar
Re: Re: Re: Re: your end of the year goals!
^ wow
what times are you putting down man those mods are nice.. man to think its all in a contourm such a sleeper i would never suspect it.
1
Shift_BOOST
97 s14
Old 12-13-2004, 08:30 PM
HighRev87's Avatar
Banned
To my understanding the T-bird has an engine very similar to the SN95 series of Mustangs, is that true? If so thats about 215 hp. a 99+GT is 260. If so you should be almost there, Im willing to bet if you got some higher end gears (not sure whats avail. for T-bird) you should have your goal....
as for beyond's car, that is amazing originality. That car is awesome, and I too would love to see times.
Old 12-13-2004, 08:39 PM
I literally just got the car back Friday from MI, from being dyno tuned. We discovered a small oil leak on the rear valve cover, so my tuning was cut short and i wasnt able to raise the boost to ~ 15 pounds. Truthfully, these cars are not meant for the drag strip. Its pretty sad when the fastest svt contour is naturally aspirated running a 13.4 @ 102 and the fastest forced induction svt contour runs a 13.5 @ 111. Traction is really an issue with these cars. Hopefully, once i get my electronic boost controller worked out, ill be running 12s, although if it were rwd, i would easily be in the 11s with 400 whp. The weather sucks right now, but it definetely hauls balls. First and second gear are useless. It just spins the tires.
"The CEG Nazi"
www.contour.org
Old 12-13-2004, 09:06 PM
CivRacer95's Avatar
CivRacer95 CivRacer95 is offline
srs biznis
Send a message via AIM to CivRacer95
Well, I'll tell you, I never met my goals for this year. Lousy year for me. But I'll tell you my next years goals:
1. Beat My dad's 3kgt.
2. Drop in new motor
3. Sell my Civic
4. Buy a Trans Am
5. Beat my Dad again
6. Make it through my probation period without getting a ticket
7. Make a pact with 4 of my buddies to get laid by the end of summer
Well, doubt any of that will happen, but who knows? It's a fresh year coming up. I can't wait for it to begin. Late...
AF Guidelines. Read and play nicely :
Just Click Here!
