Old 12-13-2004, 06:59 PM
SexyCamaroGrl SexyCamaroGrl is offline
engine swap
I have a 99 camaro v6 and I am wanting to replace the engine. What should I consider?
Old 12-13-2004, 07:14 PM
Chevyracincamaro's Avatar
Chevyracincamaro Chevyracincamaro is offline
Re: engine swap
are asking in terms of going up to a v-8. i would say stick to the v-6. you will end up spending way more than you want to step up to an eight. unless you really like your car and just have to have a v-8, i would recommend selling the car and buying a v-8...
*Better power-to-weight ratio than a C6 corvette*
Old 12-17-2004, 07:02 PM
demon9766 demon9766 is offline
Send a message via Yahoo to demon9766
Re: engine swap
Well there is alot if u cant be without your car for a while don't do it.But if u really want to replace it with a v8 u will have to redo the suspension,with v8 springs and other things,a tranny that can handle the power, new driveshaft, maybe redo your rearend, redo the wireingharnes for a v8 so your fuel system and ignition will work, and there are things I might be levin out . So if u don't have the time and money it's better to by one with a v8 in it.
Old 12-17-2004, 10:28 PM
89IROC&RS's Avatar
89IROC&RS 89IROC&RS is offline
Re: engine swap
tranny and springs are the same if i recall correctly. driveshaft is the same, rearend is the same, only the controls are different. shell need a wiring harness, all sensors, V8 PCM and BCM, probly need a brand new BCM and have it reprogramed with the options the car is now equipped with. radiator, radiator hoses, intake system, fuel delivery, exhaust, and a few other bits and peices.
Chevrolet Camaro - I enjoy beating the hell out of people
http://www.automotiveforums.com/vbulletin/showthread.php?t=68052
