Old 12-13-2004, 07:04 PM
davin28 davin28 is offline
97 cherokee sport semi-stalling problem
my jeep runs fine on my daily commute which is 30mi each way but after driving around two hours it starts acting like it is out of gas but never stalls completely. I am still able to drive it but the longer I drive, the more frequent the problem becomes. I have purchased a fuel pump but am hesitant to put it in because I have read similar posts in which changing the fuel pump and fuel filter did not help. The only successful solutions I have read are to change either the crank shaft position sensor or the throttle position sensor but I have had a diagnostic check done and nothing shows up. It seems that if it were either of those it would show up in that test. If anyone has any advice it would be greatly appreciated as I am not looking to waste money by trial and error. Thanks.
Old 12-15-2004, 06:47 AM
Cam7 Cam7 is offline
Did you do a fuel pressure test? The best way to check for a bad fuel problem. Should check it when it acts up and all driving ranges. The CPS wont always show up as bad when testing. If your problem is at low speeds or at idle check the IAC motor big problem for Jeeps. Tps should have shown up on Diagnostics check if out of wack.
Old 03-28-2005, 07:51 PM
jeepgirl123 jeepgirl123 is offline
Re: 97 cherokee sport semi-stalling problem
Ive got this exact same problem going on with my 97 XJ. I was wondering if you fixed yours and what needed to be done?
