Old 12-13-2004, 04:55 PM
Ol'Jim Ol'Jim is offline
Question '92 S-10 Quit, No Start, Blows ECM Fuse
4-Cyl, 5-spd. Co-worker was on hwy coming to work and his S-10 just suddenly quit. (Of course, when it's 25 degrees outside!).
Cranks fine, no start. Getting spark, a splash of fuel in the TB will fire it up for a couple seconds. Checked fusebox, 15A ECM fuse was blown. We borrowed a 20 A from turn signals, and it blew immediately. Does this fuse power anything else, or just the ECM? Wondering if it's a blown ECM or a short to ground? Anyone experienced this one, and solved it? Any & all ideas & suggestions will be appreciated, thanks a bunch.
-Jim.
Old 12-13-2004, 08:05 PM
snyde13 snyde13 is offline
had the same problem on my 88 s10 found it was a short on the wire going to fuel pump inside tank. the bed moved slightly to cause it to short out took off bed moved wires now prob is fixed
Old 12-14-2004, 09:49 AM
Mikado14 Mikado14 is offline
Re: '92 S-10 Quit, No Start, Blows ECM Fuse
-Jim.
Have seen this problem where the TBI wires wear through the body and short out.
Old 12-14-2004, 04:11 PM
BlazerLT's Avatar
BlazerLT BlazerLT is offline
AF -Advisor
He needs to check the wiring.
Also, NEVER put a higher amp fuse in place of a lower.
1995 Factory Blazer Service Manual for sale, PM if interested.
Old 12-14-2004, 04:19 PM
Thanks for the suggestions, guys.
Will let you know what the cause is, when it is located.
Thought I'd seen somewhere that some wiring (maybe for the F. Pump) runs under the drivers side carpet, and can wear through the insulation & short to floorboard? Anyway, all your help is truly appreciated! -Jim.
(PS: Blazer LT, I agree with you, it was a temporary swap only because no 15A fuse was available). Thanks.
Old 12-14-2004, 04:27 PM
BlazerLT's Avatar
AF -Advisor
Ah, ok, just don't want you to burn.
Old 12-15-2004, 01:31 PM
Problem solved!! Wire was touching the exhaust manifold, back where you couldn't see it. Insulation melted through. Thanks guys, for all your help!!
-Jim.
Old 12-15-2004, 02:16 PM
BlazerLT's Avatar
AF -Advisor
Nice, thanks for updating us.
Exactly where was is burnt through?
