Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Audio and Videos
Old 12-13-2004, 02:59 PM
j13jjs j13jjs is offline
Spyder Subs
I also posted this in performance... woops, Im new.
I have a 99' Spyder GS-T, its my 2nd Spyder first was a 97' GS. On all of my vehicles I like to go pretty big with the subs, I have been running into problems with my spyders. With my first one I put a Solobaric L7 12' in the trunk because it took small air space. Well it sucked because it rattled the shit out of all of the convertible componets and no amount of dynamat ever stopped it. I took that out and removed the back seat and built in a custom box with 3 p-miller 12's liquie cooled behind plexiglass. it worked well.
Now with my 99' I don't want to lose my rear seat, so im looking at other options. I have heard of taking out rear 6x9's and doing some fiberglass work to get 8's in their, but thats a lot of work for two 8 inch subs. I doubt anything will fit under the front seats. I called Hi-Fi buys and they say they can fit a box that holds 2 10's on the inside of the car out of site, he said it is between the interior and body, also said their was some minor metal cutting involved. This sounds like my best choice, but Im not going to pay Hi-Fi buys to do it? anyone have any ideas of set ups they did preserving the interior and still getting performance?
Report Post | IP: Logged
Old 12-13-2004, 05:56 PM
scottsee scottsee is offline
Send a message via AIM to scottsee
Re: Spyder Subs
2 8's will not give you deep base, their for midrange. it all depends on how tric you want to be. i think fiberglass 8's in place of the 6x9's with 6 1/2 components right next to them would be a veary nice system. that sounds really good. i think i might just do it! i've seen a couple of cars that had subs where the passenger side airbags were (where everyone puts the lcd screen) i personally wouldnt do it. i dont know man, subs just take up so much space. and its just to easy to hide them in our cars. have you tryed asking around at 4g64.com? the seats dont fold down do they?
DSM geek
Old 12-13-2004, 06:36 PM
1stGenRocks's Avatar
1stGenRocks 1stGenRocks is offline
Send a message via AIM to 1stGenRocks
Re: Spyder Subs
if the spyder has a spare tire well you can mount a sub in there.
-1stGenRocks-
95 Tsi AWD: 6 bolt, DSMLink, 880's, ACT 2600, lightweight flywheel, AGX's, Dropzone springs, poly motor mounts and suspension bushings, 3 inch turboback, gus modded 1g BOV, hardpipes, drilled & slotted rotors, 17's
plans: bastard 20g, water/meth injection NO FMIC
Old 12-14-2004, 05:47 PM
BoostedSpyder's Avatar
BoostedSpyder BoostedSpyder is offline
Send a message via MSN to BoostedSpyder Send a message via Yahoo to BoostedSpyder
Re: Spyder Subs
you are running into the same problem i got right now.
i had a JL w6v2 in a small box that was rokning very nice bass with not too much rattle. then i got a 10'' Alpine Bandpass box that barely fit into the trunk and it rattled the rear end like crazy. but then that got stolen.
now i have no idea how i'm going to go. i'm getting an ins check and probably tossing in an extra couple bux for a nice custon something or other... we will see and i'll get you guys some pix too
Old 12-17-2004, 09:27 PM
NOFX0617's Avatar
NOFX0617 NOFX0617 is offline
Send a message via AIM to NOFX0617
Re: Re: Spyder Subs
yes they would sound good, if you liked the way your solo-baric L7 12 was good, then you will like the L7 8's they hit harder than most 12's i hear.
1998 Eclipse GSX
6 Bolt swap
MHI Big 16g
FP Race Manifold
Apex'i N1 Cat-back
Apex'i N1 Downpipe
Walbro 255 fuel pump
GReddy Type S BOV
Turbo XS Boost Controller
Balance Shaft Elimininator
ACT 2600
RRE 11lb No Name Flywheel
Prothane Motor Mounts
Tokico Illuminas Advanced Handling Kit
RRE Front and Rear strut tower bars
RMDSM Front and Rear Sway Bars
TRE Stage 2 Tranny
ARP Head Studs, Main Studs, Rod bolts
Old 12-28-2004, 02:10 AM
Zero8985's Avatar
Zero8985 Zero8985 is offline
Send a message via AIM to Zero8985
Re: Spyder Subs
I've come to the conclusion that the Spyder is no good for any subs whatsoever, no matter what you do. The top is just going to continue to rattle. I tried it once. I actually tried what 1stGen suggested and placed a 12 in the spare tire well, and had it secured, the box didn't move, though i couldn't cover it back up because it was too high up (also, below it was the windshield washer fluid tank). The amp stayed back there too. I left the cardboard flooring out, and it still sounded like shit. I couldn't see out the back window to well cause of the vibrations. After two days, I took the 12 and the amp out and my cousin put the 12 back in his box for his Tahoe.
Eh... it's fine though, cause the spyders are sexier than hardtops any day of the week.
*1997 Mitsubishi Eclipse Spyder GS /// SOLD
*1997 Jeep Grand Cherokee Limited
*2000 Chevrolet Cavalier Z-24 Convertible
My Spyder on Car Domain! Check it out!!!
My Jeep on Car Domain! Check it out!!!
