Go Back   Automotive Forums Car Chat > Chevrolet > Avalanche | C&K | Silverado | Suburban | Tahoe > Suburban
Old 12-13-2004, 01:24 PM
bohutch bohutch is offline
suburban door handles
Hello,
I have a 99 suburban and have replaced the drivers and passengers inside door handles both in the last year. Now the passengers side is broken again. They are like $25 a pop at my local dealer. Anyone else have this problem? Thanks
Old 01-16-2005, 06:32 AM
Alice Alice is offline
Re: suburban door handles
Replaced the passenger side handle the once. Have a 95, wonder if yours is the same. Girlfriend with same year Chev, but not a suburban, had to replace hers twice over. Your not alone, dont blame the kids.
Old 01-17-2005, 08:32 PM
back2life's Avatar
back2life back2life is offline
face it our handles r just cheap!
Old 01-18-2005, 10:47 AM
Originally Posted by bohutch
Hello,
Hi Alice,
the handle is really easy to replace you drill out a 3/16" pop rivit near the top of the door handle assembly and slide the whole unit forward about 3/8". I guess after the first two went bad I thought I had probably replaced all the stock ones (up front). I own a machine shop and can fix lots of stuff but not these, they are cheap anyway. The first one was about $22 the last one about $34 (from the dealer).
Take care
Bohutch
Old 01-27-2005, 03:49 PM
burban boi's Avatar
burban boi burban boi is offline
i have a 95' burb i dont have problems with the handles the only problem is they arent black anymore so i put tire shine on them and makes them look new for 2 weeks.
Old 01-27-2005, 08:28 PM
back2life's Avatar
there is a bumper and trim paint that will make it last forever! get it at any auto parts store
Old 02-20-2005, 12:37 AM
benlasher benlasher is offline
What happens when your Suburban inside door handle "breaks"? I have a '99 and the inside door handle has progressively gotten worse as far as opening the door latch. Now I pull the handle all the way out and it barely opens the door.
Is it about to break? Do I replace the inside door handle assembly, or does it sound more like a cable or linkage problem?
Old 02-20-2005, 11:31 PM
back2life's Avatar
it s a big possibility its about to break not really sure if its a cable or a linkage in there, might want to tear the door down and investigate the actuation of the handle. the problem can be anywhere
Old 02-21-2005, 09:35 AM
gregory914 gregory914 is offline
My 97 Burb drivers door handle broke about a year ago, drove with it busted for a couple months, what a pain! Found an aftermarket one online for $16.00 and took 10 minutes to fix. It took me longer to figure out how to get the door panel off than it did to actualy replace the part. You take the trim piece off around the handle, the srews by the armrest, the little cover by the mirror and then just pull the door panel off starting at the bottom and away you go, drill out the rivet, install the new handle with a rivet, and put the panel back on .
They break because they are cheap pot metal which means, once it starts to crack ...it's gone.
Old 02-21-2005, 09:42 AM
I need a lock actuator as well, and will do this at the same time. Dealer says $90 for the acuater, on-line (A1 I think) says $29. Any benefit to paying the $90, other than the fact I can get it now.
Old 02-22-2005, 04:13 PM
None that I can tell, A1 is where I got my handle for $16 a year ago and it's still working fine.
Old 04-09-2005, 08:39 AM
CalessaSSracer CalessaSSracer is offline
argggggghhhh my front passengers just broke!!!!!!
Old 05-27-2005, 07:08 PM
greg0163 greg0163 is offline
Re: Re: suburban door handles
Hoping that gregory914 can help in regard to - "take the trim piece off around the handle" - how in the world does it come off? I'm afraid the things going to break if I try to hard. Any details on how to get that trim piece off?
