Go Back   Automotive Forums Car Chat > Oldsmobile > Cutlass Series
Cutlass Series Includes Cutlass Ciera, Cutlass Cruiser, Cutlass Calais, Cutlass Supreme, Custom Cruiser, as well as the GM N-Body subforums.
Old 12-13-2004, 12:59 PM
troyfromkamilla troyfromkamilla is offline
Question whining 94 Cutlass Supreme
I have a '94 Cutlass Supreme SL with a 3.4L V-6. Recently it started whining at idle and when stopped (not squeeling or grinding) and it's putting a serious drain on the engine, it doesn't stall but the voltmeter drops considerably and the lights dim quite a bit. It sounds kind of like the power steering pump but there is no change in the feel of the steering and turning the wheel doesn't seem to effect it. It doesn't do this when going down the road or when the rpm's are up. Any ideas / experiences?
Old 12-13-2004, 08:42 PM
jmblimo's Avatar
jmblimo jmblimo is offline
Pull one of your timing belt covers off and take a look at the belt. Mine was doing the same thing and the problem was a timing belt idler pully. When I looked at the belt it was halfway off of the cam gear. I believe the whine was the belt rubbing the housing.
With your power problem, it could also be your alternator.
FLEETWOOD MIKE
Old 12-21-2004, 02:55 PM
swiber swiber is offline
might the alternator or the ac conpresor or somthing as easy as the belts being dry
