Closed Thread Show Printable Version Show Printable Version | Subscription Subscribe to this Thread
Old 12-13-2004, 12:16 PM
Red 99 Mustang's Avatar
Red 99 Mustang Red 99 Mustang is offline
Send a message via AIM to Red 99 Mustang
5.0 v 4.6
ok i wanna get a new car, either a 95 5.0 or a 99-04 4.6, at first i thought the 5.0 was faster, jus b-cuz the engine size, but i did some research and saw that the 4.6 has more hp, now which would you say would be faster/get more hp, and which would handle mods better?
Old 12-13-2004, 01:05 PM
DDMTK421DS's Avatar
DDMTK421DS DDMTK421DS is offline
Send a message via MSN to DDMTK421DS
Get an 05 and you can beat them all. .......................
Old 12-13-2004, 01:38 PM
Muscletang's Avatar
Muscletang Muscletang is offline
AF Premium User
You are looking at two totally different types of engines here. The 4.6 is an OHC (or DOHC) and 5.0 is an OHV.
The 4.6 can whined higher than a 5.0 can and has a higher power band.
The 5.0, on the other hand, can't whined like a 4.6 but is more of a bottom end engine. It has some power sitting at idle.
To sum it up, the 5.0 is a torque machine that is really good as a bottom end monster. The 4.6 has to whine itself up a little before it starts to get some power but it makes it a good high end engine.
Old 12-13-2004, 02:55 PM
duplox's Avatar
duplox duplox is offline
Send a message via AIM to duplox
Re: 5.0 v 4.6
Not quite.. the way the motors came from the factory, the 4.6 had more high end and the 302 had more low end torque, this is true. But the 4.6 has a smaller bore and longer stroke, which is much more of a low-end thing. The 302 has a big bore and small stroke, which lends itself nicely to high rpms, as well as a very small main bearing diameter. I'm not sure what the 4.6's main bearing diameter is. Short stroke lessens piston speed, big bore allows big valves/a lot of flow, and compensates for short stroke. Shorter stroke also reduces the crank's moment of inertia at a given speed, by having a reduced diameter and reduced weight.
An OHC motor's valvetrain is capable of sustaining higher RPMs than an in-block cammed OHV motor. This does not mean that it is neccesarily a better high rpm motor.
Another big factor in high-rpms is obviously head flow. 302s have a terrible valve setup, basically the worst OHV setup. A (big) step above flatheads.. Inline 2v. The 4.6 has a 4v version which will put any stock (and many aftermarket) 302 head to shame. In this way, the 4.6 is more suited to higher rpms.
Ideally, for a high rpm screamer, you'd want a big bore, short stroke, small main diameter, high flow DOHC headed motor. For low RPM you want long stroke, smallish bore, average main diameter, and low intake port volume headed motor.
Basically, if the 302 had DOHC heads (as the 4.6 does), it'd outrev the 4.6 easily. Even with some aftermarket OHV high flow heads, it'd outrev a 4.6.
now back to your question - 5.0/302 is old technology, I'd personally much rather have a 4.6. Much more potential.
Old 12-13-2004, 03:40 PM
HighRev87's Avatar
HighRev87 HighRev87 is offline
Banned
Re: 5.0 v 4.6
One of the things I realized when doing my research is for the price of a used 99-04, you could buy a 5.0 and make it a beast. That is one of the things I considered, but it was more economical for me to get the 4.6. I enjoy it, and havnt looked back.
Old 12-13-2004, 03:43 PM
burntrice087 burntrice087 is offline
Banned
Re: 5.0 v 4.6
Both the 4.6 and the 5.0 werent that good stock...They both had 215HP from a V8 which in my opinion is pretty underpowered...Howver the 5.0L has a pretty decent aftermarkewt and takes well to mods and loves to take boost...The 4.6L is more of a top end power type and benefits from having overhead cams
Old 12-13-2004, 04:02 PM
HighRev87's Avatar
Banned
Re: Re: 5.0 v 4.6
Wow I love when you talk and dont know much. I drive a 4.6, and I have 260 hp. He was looking at a 99+ which would be 260hp.
Old 12-13-2004, 08:16 PM
eillob's Avatar
eillob eillob is offline
I'll take the 5.0 torque monster. Ive driven and raced 4.6's and I just don't care for them. The only exception for me would be the 04 Cobra.
Ported Cobra Intake, Ported & polished Windsor Jr heads, K&N, Vortech s-trim, 90mm Lightining mass air meter, 70mm throttlebody,1.7 roller rockers, BBK Long tube headers, offroad H-pipe, Crane cam, main cap girdle, 40 series flowmaster, 3.73 gears, MSD ignition, CGS subframes, A9L PIH kit, SCT custom burned chip, 42lb injectors, 190lph fuel pump, T rex and fuel pressure regulator, AFCO racing radiator
(If it doesn't scare the Hell out of you it isn't fast enough)
Old 12-13-2004, 08:52 PM
emokid15 emokid15 is offline
Re: 5.0 v 4.6
well i would get the 5.0. well get what u want its all good its still a mustang.
1987 Ford Mustang 5.0 GT ( Stock )
Old 12-13-2004, 10:12 PM
Muscletang's Avatar
AF Premium User
I also forgot to add that I've had the pleasure of driving both types of cars. I have my 86 (auto) and my dad's 90 (5 speed) to drive around. My cousin just got an 04 (5 speed) and she let me drive it around some.
This how I see things after driving both types of cars. The 5.0 will put you back in your seat the moment your foot starts to lay into the gas. Once you get up near max torque the thing starts to slow down some. It still will lay you back, but not as much as when you started out.
Now the 4.6, when I put my foot into the gas it layed me in my seat, but it didn't have the grunt at the start the 5.0 did. Once the 4.6 reved up a bit it hit its power and shot off, then the thing really layed me back.
This is just my personal observation of these engines in action.
Also, I noticed this little thing about the cars while driving them. In the 90 I can get the thing down to around 700-800 rpm before it really starts to lug down.
In the 04, I noticed the thing started to lug down around 1,000-1,100. I also should note that I was going up a hill in it as it started to lug down. It wasn't struggling but the engine was getting a little bogged down. I've gone up the same hill in the 5.0 and it had no trouble while reving that low.
I love driving both cars but when picking one I'd go with the 5.0. In the end it's about what you want. Do you want the bottom end torque of a 5.0? Or would you rather have the higher end horsepower of a 4.6?
Also, you guys are talking about mods and what they do with both engines. Well 5.0 & SF magazine did a mod test with the 5.0 and 4.6. They put the same mods on for both engines. The 5.0 will give you more horsepower and torque per mod. The 4.6's mods though are cheaper to get, but just won't give you as much power.
Old 12-14-2004, 12:28 AM
zx2srdotnet's Avatar
zx2srdotnet zx2srdotnet is offline
Banned
Send a message via AIM to zx2srdotnet
Re: 5.0 v 4.6
I don't have a Mustang but unless its a 01 cobra or 03 Mach1 i wont touch a 4.6. I just see them as shit motors. No matter what they will ALWAYS be compaired to the 5.0. That and im a tq fan. I could only afford an I4 due to a college budget but in 00 I bought the one with the most N/A tq that I could afford lol. Feels good to make more tq at the wheels then more expencive cars like a 00 Si and even with an Intagra Type-R lol
Old 12-14-2004, 01:04 AM
ModMech's Avatar
ModMech ModMech is offline
Re: 5.0 v 4.6
Well, the 4.6L has the LOWEST WARRENTY COST per unit of ANY engine EVER MADE (in a production car). I would hardly consider that bad, let alone shitty.
If you are unfamiliar with EFI, and just want a really good quick car, the 5.0 is, IMO, the best choice. If you are comfortable with EFI and/or want to do a lot of power mods, then the 4.6L is FAR more adaptable due to it's vastly superior computer.
What ever you do, DO NOT rev a 4.6L over 6200, because at 6250 the "con-necting rods" become "dis-connecting" rods, and you ventilate the block.
As to which engine is "better"....
There are tons of aftermarket parts for BOTH, more for the 5.0, but it's been around for 40 YEARS, as opposed to about 15 for the 4.6L.
You don't hear of too many older vehicles with 300,000 miles plus on them (5.0), but it is COMMON with the 4.6L. So which is more durable? The 4.6L no contest.
Old 12-14-2004, 06:10 AM
would it be possible to put a 5.0 in a 99+ body...jus a question
Old 12-14-2004, 06:24 AM
eillob's Avatar
Well I haven't seen the article so I don't know what mods they were doing. However I do know that a guy at work showed me the price to put cams in his 03 and it was about 10 times as much as would have cost me to put one in mine.
Old 12-14-2004, 08:40 PM
silverstangs's Avatar
silverstangs silverstangs is offline
Send a message via AIM to silverstangs
Everyone says they perfer the torque of the 5.0L(technically 4.9L), but the 5.0L did not make more torque than the 4.6L. The 5.0L had a DIFFERENT TORQUE CURVE than the 4.6L. That torque curve is also based on the cam in 5.0L and the CAMS in the 4.6L. I don't know how many of you all seen the cams in the 4.6L, but they are nothing more than pencil sticks. They got a TINY change for 03-04 but still sticks.
1986 5.0L V8 hp 200@4000 TORQUE 285@3000 (technically 4.9L)
1991 5.0L V8 HP 225@4200 Totque 300@3200 (technically 4.9L)
1992 5.0L V8 HP 225@4200 Torque 300@3200 (technically 4.9L)
1994 5.0L V8 HP 215@4200 Torque 285@3400 (technically 4.9L)
1995 5.0L V8 HP 215@4200 TORQUE 285@3400 (technically 4.9L)
4inch bore * 3 inch stroke = 302 cubic inches which = 4.94L
2001 4.6L V8 HP 260@5250 302@4000
2002 4.6L V8 HP 260@5250 302@4000
2003 4.6L V8 HP 265@5200 310@4000
2004 4.6L v8 HP 265@5200 310@4000
Here's one for everybody... the stroke of a modular is 90mm and the bore is 90.2mm which = 281 but the advertized bore is 3.6inches which is 91.44mm and the advertized stroke is 3.6inches which is 91.44mm which = 293 inches aka 4.8L
If your really want a 5.0 engine, just take your average every day 4.6L modular engine..... bore your engine out to 3.6inches aka 91.44mm and stroke it to 3.75inches aka 95.25mm and you have your 305cubic inches which really is 5.0L.
As far as swapping cams, I'm getting ready to do that myself. It's not difficult at all, just a little time consuming, and can be done in your garage. What makes it time consuming is that you have to remove everything from the front of the engine. I will be installing comp cams, I went with a mild set. I'm waiting till after Xmas to install them.
My ride at my site Silverstangs.
Closed Thread
