Go Back   Automotive Forums Car Chat > Oldsmobile > Aurora
Old 12-13-2004, 10:15 AM
VFRDYLAN VFRDYLAN is offline
Chasing electric drains/shorts
I have a new issue that has developed on my 95. There appears to be some perpetual drain on the electric system. If I leave the car idle for more than 1 day, the car is completely dead and needs to be jump started.
In the past year I have purchased a new battery (Jan 04) and put in a new alternator (June 04). When running, the car is charging fine. Generally at about 15.3.
In the last month, I had by fuel rail changed by the dealer.
Is there a good way to begin chasing the cause of my dead car? Any other possible causes?
Old 12-13-2004, 10:59 AM
Roraman Roraman is offline
Electrical drains/ shorts
First, determine that you have a good battery. If you have done so, please read on. You can use a standard volt/amp meter. Be sure to have the leads connected between the positive terminal and and positive cable. This will enable you to read current drain with the systems de-energized. Be sure to have everything turned off, all lights, radio, engine off, key out of the ignition. If you have a current drain as low as .1 amp, this is enough to eventually cause the condition you have described. With the meter connected, systematically go through each fuse box and remove a fuse one at a time (and reinstall after reading meter). This will allow you to identify which system has the drain. Happy hunting.
Old 12-13-2004, 12:22 PM
Re: Electrical drains/ shorts
Originally Posted by Roraman
You can use a standard volt/amp meter. Be sure to have the leads connected between the positive terminal and and positive cable. ...... With the meter connected, systematically go through each fuse box and remove a fuse one at a time (and reinstall after reading meter).
Roraman,
Thanks for the tip, but I'm a rookie with a voltmeter.
Follow up question. The meter has two wire/probes, a + and -. Am I putting the meter probes into the fuses ? Where would the negative lead on the meter be connected? Is it to the batery?
You state to have leads connected between the + terminal and + cable. Can you elaborate?
Thanks
Old 12-13-2004, 05:59 PM
Retro-D Retro-D is offline
Re: Re: Electrical drains/ shorts
Originally Posted by VFRDYLAN
Roraman,
For the electrically challenged or Amish, a good place to learn about circuits before you fry something.
http://www.ndt-ed.org/EducationResou...iescircuit.htm
RD
Old 12-14-2004, 11:05 AM
LesGrandsPieds LesGrandsPieds is offline
Is your antenna functioning correctly?
If it can't go down all the way then it'll drain the battery trying to put itself back down.
Old 12-14-2004, 12:08 PM
Apologies
Sorry guys, I sometimes assume a lot. Also, a good point about the antenna. All little motors (power antenna, seat belt retractors, etc.)remaining energized after securing the vehicle will cause this.
Old 12-14-2004, 12:29 PM
Re: Chasing electric drains/shorts
My antenna has been acting up. Sometimes it gets stuck (up or down). Although I generally can hear the motor running, I'll have to look at it closer.
I read the electric basics and already had a general understanding of them, but some of the tools and testing is what gives me trouble.
I can test for resistance, it is just the steps for see a continuous drain still a bit vague.
