Go Back   Automotive Forums Car Chat > Ford > ZX2
Old 12-13-2004, 11:14 AM
Dvogel Dvogel is offline
Question Stuck in Park
My car is a 2001 (and only 33K miles), it is an automatic and it is stuck in park, brake lite stuck on as well. Transmission fluid is fine I just cant get it in gear. Anyone have any ideas for me to try before i have to have it towed and spend an arm and leg on it??
Old 12-15-2004, 12:01 PM
jeffcoslacker's Avatar
jeffcoslacker jeffcoslacker is offline
Lactose the Intolerant
Re: Stuck in Park
Sounds like something narfed up in the brake/shift interlock relay or switch. Look up at the top of the brake pedal, and you may see the problem.
You made three mistakes. First, you took the job. Second, you came light. A four man crew for me? F**king insulting. But the worst mistake you made...
...empty gun rack.
Old 12-15-2004, 12:02 PM
Re: Stuck in Park
The shifter won't move, correct?
...empty gun rack.
Old 12-19-2004, 10:31 PM
missouri03l missouri03l is offline
Re: Stuck in Park
Hey man,
I just had the same problem and it was the shift-interlock relay that hosed up on me.
You can bypass the interlock by finding the hole next to the shifter and pop out the tab. Then just stick a screw driver to disengage the lock.
Hope this helps!
