Go Back   Automotive Forums Car Chat > Honda > Let's get Technical!
Let's get Technical! Discussion for hardcore in-depth motor heads!
Old 12-13-2004, 09:30 AM
Kurt@xrodz Kurt@xrodz is offline
Question? connecting rods
Hi,
What are the best connecting rods for B16 & or B18 honda motors? Does anyone make a hard anodized or teflon impregnated coated aluminum rod for these engines? Any reply's will be greatly appreciated.
Thanks
Kurt
Old 12-13-2004, 01:24 PM
civickiller civickiller is offline
Send a message via AIM to civickiller
Re: Question? connecting rods
best rods are pauter rods
Team Lonely Drivers
Old 12-13-2004, 03:43 PM
whtteg's Avatar
whtteg whtteg is offline
Send a message via AIM to whtteg
Asking what the best of something is always going to get you opinons, so remember that.
Old 12-14-2004, 09:14 AM
bohutch bohutch is offline
Thanks
Thanks civickiller. Right now opinions is all I'm really interested in. Just out of curiosity do you know anyone racing these?
Old 12-14-2004, 02:21 PM
th_james2003 th_james2003 is offline
eagle
Old 12-14-2004, 02:32 PM
Kven's Avatar
Kven Kven is offline
ib spec
HondaSwap | K20A.org | EF Honda
1988 Honda CRX DX
WTB: CRX mudflaps(both front and rear)...PM me if you have some for sale!!!
Old 12-14-2004, 03:43 PM
Anyone ever run Bill Miller (BME), GRP or English Eagle (not the chinese "made in America" rods but the high quality Aluminum rods?
Old 12-14-2004, 03:47 PM
Kven's Avatar
i would think that aluminum might be kind of weak for a connecting rod. most people stick with steel or if they go for something better its usually titanium.
1988 Honda CRX DX
Old 12-14-2004, 04:39 PM
All funny car and top fuel cars run Aluminum rods? I know they are running several thousand horsepower (pretty sure they run a lot of BME rods) I also know they rebuild after every run and replace the rods at each rebuild (can you imagine the cost). I was a crew chief in Formula atlantic (all Toyota four bangers) and you almost always seen either Carillo steel rods or high end aluminum rods. Thanks for your input Kven.
Old 12-14-2004, 07:42 PM
Kven's Avatar
wow i never knew that. are the designs of the aluminum rods similar to that of the steel and titanium ones(like the I-beams and such)? ive always wanted a lighter conrod for the b16 im putting in but can only find steel units, and titanium but theyre way too expensive. also, how do the prices for aluminum units compare?
1988 Honda CRX DX
Old 12-14-2004, 08:36 PM
Re: Re: Question? connecting rods
I was researching different connecting rod designs (I work for a Mechanical and Material science department at a State University) using a technique call F.E.A. (Finite Element Analysis) and found some really interesting information about rod designs. I did analysis on a Carillo rod (H-beam (steel), a stock Ford connecting rod (from a 302), Mopar 440 six-pack rod and Mopar 340 stock. The last three rods are all "I" beam rods.
1) the mass of connecting rods is very dependent on their overall strength because there are actually higher stress levels on the rod from dynamic forces associated with their rotating through their normal, intake, compression, ignition, exhaust cycles than what occurs during compression stress associated with being pushed on by the piston alone.
What this means is the lighter the better.
2) Aluminum rods can be substantially stronger than steel rods when properly engineered and made from the right material.
3) If I were building a motor for a Honda B16 and performance was a consideration aluminum would be the most logical choice.
Like you said the Titanium rods are very strong but they aren't as light as you might expect (typically TI rods weigh about 150% as much as the same design as Aluminum) and the way they price them you would think they were made of gold.
I hope this helps.
Old 12-14-2004, 10:07 PM
Re: Thanks
mike laskey, running 10s
Jotech, car in the hotrod class
this is what i plan to run in my engine when i build it
Team Lonely Drivers
Old 12-16-2004, 06:58 PM
Re: Re: Thanks
Are you running Pauter rods in your Jotech? Steel or TI? I looked at their TI rods but damn, they want like $800 each. Thanks
Old 12-17-2004, 10:31 PM
im not apart of jotech so i dont know if its steel or Ti, probably steel
Team Lonely Drivers
Old 12-18-2004, 12:57 PM
boosted331 boosted331 is offline
Street car or race car?
We ran GRP aluminum rods in a friends mustang that he loosely called a street car (15:1 compression 459" SBF), and after about 1000 street miles on the car in one summer the piston-to-deck clearance tightened from .015" in the hole to .004" in the hole. They strech way too much to be used in a street car. The lightest rod you're going to be able to use for a street car is a titanium rod. Eagle already has one out, so why mess with a good thing
