Go Back   Automotive Forums Car Chat > Dodge > Intrepid
Old 12-13-2004, 08:54 AM
Aarontandoh Aarontandoh is offline
Thumbs up Does anyone know how to program the keyless entery for a 94-95 dodge intrepid?
Please need help doing it. Thankz much!
Old 12-13-2004, 06:24 PM
wafrederick wafrederick is offline
Banned
Take it to the dealer.Has to be programed with Chrysler's factory scan tool,DRB III
Old 01-03-2005, 12:30 AM
salcidomd salcidomd is offline
Thumbs up Keyless entry
Hey this worked for me.
http://www.dodgeintrepid.net/forums/...threadid=32429
Mario Salcido
Old 05-12-2005, 11:27 AM
95grnintrep 95grnintrep is offline
Smile Re: Does anyone know how to program the keyless entery for a 94-95 dodge intrepid?
I heard from someone that that if you use a paperclip and put it in the green wire hole and the black one it would work and I had to get a new remote for my 95 Dodge Intrepi and I tryed it and it worked. you turn on car (but don't start it) just on then put the paperclip in and your doors should lock and unlock. It's that easy.
Old 05-19-2005, 08:22 AM
Onblsht's Avatar
Onblsht Onblsht is offline
Authorized Vendor
Remove the middle vent bezel from the instrument panel.
Locate the 2x3 traction control black connector. The connector will either be connected to the switch or the back of the bezel housing. Disconnect the connector.
Turn ignition switch to the ON position.
Ground pin 4 of the traction control connector. This is the programming line for the Remote Keyless Entry Module. The door locks will lock and unlock, to indicate the receiver is ready to receive transmitter code. The trunk solenoid will not cycle at this time.
Press any button on the transmitter to set code. The locks will cycle to confirm programming. If there is a second transmitter it must be set at this time. Press any button on the second transmitter and wait for the locks to cycle.
Disconnect the program line from ground. This returns the system to its normal operation mode.
Attach the traction control switch connector back to its original position:
Traction control switch
Back of the bezel housing.
Replace middle vent bezel, to the instrument panel. If the vehicle has a traction control switch check for functionality once the bezel is in place.
Replacement keyless entry remotes available here - up to 90% off -
All makes/models from Acura-Volvo, 1988-present -
http://www.OriginalKeyless.com
Old 06-22-2005, 09:33 AM
vballjody vballjody is offline
A very stupid question--How do I get the middle vent bezel out?
