Manual Transmission Help
Howdy Folks.
I have a 98 accord lx. It runs good except when its warm and I try to change the gears, the clutch becomees free and my gear box becomes jammed. For example, it happens if I try to do a tight 3 point turning. The gears become locked and don't change. Pumping the clutch doesn't help. The clutch becomes free. I turn the car off and then back on and it becomes ok.. until the next time I need to reverse. Highways is perfect since I don't need to change the gears at all :-) the car has 80K miles and I had the clutch replaced at 67K (which seems awfully soon for a honda). The problem didn't go away after replacing the clutch. Help.. |
Hmmm It could be quite a fiew things...
1:Problem: Pedal travels to floor - no pressure or very little resistance. -possible causes: 1: No fluid in the clutch fluid reservoir 2: Faulty cluts master cylinder, release cylinder or hydraulic line. 3: Broken release bearing or fork 2: Problem: Unable to select gears -possible causes: 1: Faulty transaxle 2: Faulty clutch disc 3: Release lever and bearing not assembled properly 4: Faulty pressure plate 5: Pressure plate-to-flywheel bolts loose I took these troubleshooting symtomps from my repair manual... I hope it helps ... good luck! |
