need help I am getting my blazer ready for winter and I was checking out the 4x4 and when I push the toggle button some times I hear the solenoid on the transfer case engage and some times not .when it dose the light on the button will come on for a second then go back off while looking for electrical problems I seen where my loving dog chewed the wires off my front axle solenoid so I replaced bad wirers but still no luck .it also seems to try to lock in easier in neutral but still will not stay engaged . My blazer is a 94 s-10 4.3 w 4x4 I could use any and all help thanks
Re: 4x4
Check the eletronic shifter [encoder]. Also something I seen on here for a temp fix or check. Unplug your negative side battery for 30 mins. Then hook it back up and check. resets puter. I guess your encoder is going bad or is bad.
Re: 4x4
ok thanks how do you check the electric shift encoder?
Re: 4x4
10 mins is all you need to do the battery off thing.
i know all to well :/ checking the encoder has been coverd all over the forums...very common topic..under almost all 4x4 problem posts.........good luck. |
Re: 4x4
Thanks for the info I unhooked my neg .bat. cable for a few minute and that didn’t do any thing thin I did the positive cable and it worked a couple of times till I backed it out of the garage now it is back to only trying to work in neutral again . I read the other post and if the encoder is the little motor on passenger side then I can hear it engaging when I can get the light to work
Re: 4x4
Dealer cost for a encoder with 1 year warranty $400. Junk yards $100-$150. Ebay $100. Sounds like you need one.
if you decide that you need a decoder mod. I have 2 i would be happy to sell you one for less than the junkyards. I know how hard it is to find a parts truck. let me know.
Re: Re: 4x4
The part that I have is the encoder module. This is the computer part that is behind the dashboard. I still have 2 extra let me know if you need this part and ill give you my e-mail address and we can talk privately
Re: 4x4
The encoder motor is on the transfer case . the part under the dash is call TCCM Transfer case control module
Re: 4x4
Which one is it? Can anyone clear this up?
Re: Re: 4x4
Anyone? TonyFDNY? Fireplug? Hello? |
Re: 4x4
under the driver side lower panel is the ALDL test connector. there should be a black plastic connector with 2 rows of 6 spots the top right is pin a then going to the left is pins b,c,d,e,f, on the lower 2nd row starting on the right is pins m then going to the left is pins l,k,j,h,g
What i want you to do is take a jumper wire from pins j and a and turn the ign key to run(do not start the truck) and look at the 4wd lights will flash a code get that code so I can help pin point the problem also I want you to just turn the ign key to the run position with out the jumper wire on pins j and a and tell me what the 4wd lights do. I have the trouble tree for that system with me right now |
Re: 4x4
ok i will get to it tonight. Thanks for the help
Re: Re: 4x4
With the jumperwire plugged in A and J with the key turned on the run position I got 3 flashed on the 4x4 switch and that was both lights. With the wire out of the connector and the key turned to the run position I got nothing. Let me know what you find out Thanks Dave |
