Old 12-13-2004, 07:59 AM
clawhammer's Avatar
clawhammer clawhammer is offline
Hood won't open
I need help!!! Yesterday I intalled my new radiator, and filled it up with coolant, and closed the hood, took for a spin, everything seemed fine, then wanted to check the coolant levels and get the air out, and I noticed that I couldn't open the hood anymore. It seemed as if the plastic piece would not do much till I had it pulled about halfway, only then would it grab, and when it was pulled out all the way, it didn't open the hood. Then I tried adding more force, by pushing on the cable while it was pulled out all the way. How do i fix it?
Old 12-13-2004, 10:23 AM
honda_luvr_2000 honda_luvr_2000 is offline
Re: Hood won't open
i had the same problem happen to my rex. take the cable off the back of the lever u pull on, and pull it w/ pliers to get u'r hood to pop. as for fixing it, i just got another used one.
Old 12-13-2004, 10:49 AM
TheSilentChamber's Avatar
TheSilentChamber TheSilentChamber is offline
Forunn Daberator
Re: Hood won't open
have someone push down on the hood as your pulling the latch.
Old 12-13-2004, 01:00 PM
4-Door Flunky 4-Door Flunky is offline
AF Premium User
This happened on my car. The problem is right there on your handle. Feel around behind the handle and find the place where the cable comes in. If the cable drops 1/4 inch down, the hood won't open. If you push the cable up a little bit, then pull the handle, you get that extra little bit necessary for it to pop open.
Stay away from the pliers; you'll damage the cable.
Flunky
PS-It's a cool trick, because after you've got it down pat, you're the only one that can open your hood! Consider it a security feature, and ask for an insurance discount!
Old 12-13-2004, 01:07 PM
]{iwi's Avatar
]{iwi ]{iwi is offline
Registered User
Send a message via MSN to ]{iwi
Re: Hood won't open
l0l
Old 12-13-2004, 02:01 PM
icE_x's Avatar
icE_x icE_x is offline
Send a message via AIM to icE_x
Re: Hood won't open
haha, didnt kno that things wrong with ur car could give u security discounts call up insurance and say you have an anti-theft device installed, and if they ask what kind, jus say they wont be able to steal your spark plugs anymore haha : p
1990 Civic EX 4-Door Sedan - D16A6 - 204k miles
:: working on mechanical and cosmetic restoration ::
Old 12-13-2004, 03:56 PM
clawhammer's Avatar
Re: Re: Hood won't open
This fixed the problem
Old 12-13-2004, 05:12 PM
V-K V-K is offline
Send a message via AIM to V-K
Re: Hood won't open
My Civic does that sometimes too. You can usually walk to the front, push it down, and then pop it with the latch. Maybe the cable gets stretched over time?
Old 12-13-2004, 09:27 PM
1PhatCX's Avatar
1PhatCX 1PhatCX is offline
mine does it
i just hold the handle up and smack the hood in the center near the front and it pops open
Old 12-14-2004, 07:02 PM
Canabalooza Canabalooza is offline
Re: Hood won't open
i just push tword the middle with my hand and pull it then again my arms are way long.
Old 12-14-2004, 09:28 PM
Ones&zeros Ones&zeros is offline
Send a message via AIM to Ones&zeros
SAME W/ ME AFTER MY ACCIDENT I NEED AN EXTRA PERSON TO OPEN THE HOOD...SUCKS...
Old 12-14-2004, 10:45 PM
crxlvr's Avatar
crxlvr crxlvr is offline
Slowest Automatic Civic
Send a message via AIM to crxlvr
Re: Hood won't open
on one of my friends cars we just pull the release and then go around and push the hood down and it would pop open, one person only.
Stable Of Cars I have Owned:
1991 Honda CRX
1990 Oldsmobile Cutlass Supreme
2003 Honda Accord
1998 Chrysler Concorde
2007 Honda Civic
1997 Toyota Camry
1995 Saturn SC2
1996 Ford Taurus
1991 GMC Sierra
2002 Daewoo Leganza
1999 Dodge Ram
2007 Honda CR-V
2003 BMW 325i
