Old 12-13-2004, 06:56 AM
viper687 viper687 is offline
Angry Amp Questions
I recently hooked up a 850 watt amp and everything works fine except for the fact that every time I plug the RCA cables in the amp I get this whistling sound from the speakers and it gets louder everytime I press the gas in the car! The only time I hear this noise is when the RCA cables are plugged in the back. Any help is greatly appreciated
Old 12-13-2004, 07:48 AM
sr20de4evr's Avatar
sr20de4evr sr20de4evr is offline
Re: Amp Questions
are the rca cables run next to the power cable?
if you leave the rcas plugged into the amp, and you go up to the headunit and unplug them there, does the sound go away?
'01 Black Sentra SE
Weapon-R intake, HS header, HKS catback, ES motor mounts, B&M short shifter, Tein coilovers
Alpine 9835, Adire Koda 6.1, Adire Brahma 15, Arc 2100cxl, Linear Power 2.2hv, Cadence ZRS-8
'05 Silver WRX STi
Injen SES Downpipe, HKS Carbon-Ti catback, Cobb Stage 2 Tune, TiC Super Shifter, TiC Klunk Killer, Tein springs, Nitto NT555R Drag Radials
Old 12-13-2004, 09:52 AM
If I plug the RCA cables in the amp and not the cd player it does not make the noise..and if I plug the cables in the cd player and not the amp it doesn't make the noise...it only does it if both are plugged in and no it is not run beside the power wire... I've had an amp before and never had this problem.
Old 12-13-2004, 11:52 AM
sr20de4evr's Avatar
Re: Amp Questions
check your headunit's ground, if it's grounded through the wiring harness currently, try grounding it yourself to some bolt in the dash.
'01 Black Sentra SE
'05 Silver WRX STi
Old 12-13-2004, 03:52 PM
RickwithaTbird's Avatar
RickwithaTbird RickwithaTbird is offline
Send a message via AIM to RickwithaTbird Send a message via MSN to RickwithaTbird Send a message via Yahoo to RickwithaTbird
Re: Amp Questions
go to wal mart and get this little thing called a "Ground Loop Isolator". its like 12 bucks. It will clear that right up for you no problem at all. Ive had several different systems in my car, and some made no whining noise at all, and some made horrible whining noises with the same wiring. That kind of thing is tempermental. You can fool with it for weeks and never fix it, or you might just need to clean your grounds, this and that and the other obvious things, but if nothing works, a ground loop isolator will.
Old 12-13-2004, 11:19 PM
aznxthuggie's Avatar
aznxthuggie aznxthuggie is offline
Re: Amp Questions
reground, or buy the thing rick recommended
Old 12-14-2004, 12:06 PM
PaulD PaulD is offline
Audio Guy
Send a message via AIM to PaulD Send a message via Yahoo to PaulD
be careful of cheap ground loop isolators that goinline with your RCA's. If the inductance is wrong,it will act like a high pass filter (cut your bass level)
