Old 12-13-2004, 04:23 AM
Thourun's Avatar
Thourun Thourun is offline
Send a message via AIM to Thourun
New tunable MAF
I was browsing 3SI and came across a new kind of MAF that is easier to tune than the MAFtuner or the ARC-2. Here is what it is http://www.spmotorsports.com/dsm_intake_proflow.html
And here is the discussion on 3SI about it
http://www.3si.org/forum/showthread....2&page=1&pp=10
I plan on getting a 2nd gen VR4 as soon as I find the right one and I plan on spending most of my summers earnings moding it, this may or may not include bigger turbos depending on how much money I can make. If I find that the bigger turbos will have to wait till the school year or the next summer would moding the fule system with bigger injectors (660cc?), fuel pump, and fuel management (like this) be a good idea? I guess what I'm asking in essence is would it be worth upgrading the fuel system before buying bigger turbos. I plan on getting the following mods during the summer before considering upgrading the fule and turbos.
K&N 9" filter ($40), dual setting MBC or EBC ($75-$350), vacume/boost gauge ($50), Borla ($650), test pipe ($40), Downpipe ($250), Gut precats ($0), Tien S-Tech springs ($200), Stillen rotors and pads ($250)... and maybe, a set of HIDs ($285), Enkei RPM2 wheels ($1200) or 5 Zigen FN01-RC wheels ($1100). Ohh and probably some DIY angel eyes.
I should be able to make enough money for the first round of moding in 2-3 weeks, What do you think?
1995 3000GT VR-4
Installed: ESP front precat eliminating downpipe, test pipe, RF-1008 K&N, Dejon tool Y pipe, 1G DSM BOV, MSD wires, Guted rear pre cat, ISSPRO EV Marine boost gauge, IPO MBC, EGR blockoffs, Palm m515 dataloger setup, NGK iridium plugs, SPEC stage II clutch 500ft/lb, 5300k HID plug and play setup.
Soon:Topline Engineering ground wires.
Old 12-13-2004, 09:02 AM
uncutnick3kgt uncutnick3kgt is offline
Send a message via AIM to uncutnick3kgt
with bigger turbos a better fuel system is a must....so it would be a good iedea to get bigger injectors and a better fuel pump...and yes a tuning device to keep it all in check
Old 12-13-2004, 10:37 AM
Thourun's Avatar
Re: New tunable MAF
Yea I get that, but would it make any sense to do it well in advance of the turbo upgrade (looking to be a largish TD04 setup like DR650s).
1995 3000GT VR-4
Old 12-13-2004, 01:29 PM
Linebckr49's Avatar
Linebckr49 Linebckr49 is offline
Send a message via AIM to Linebckr49
no, it wouldn't make any sense to upgrade the fuel system BEFORE you upgrade turbos; you would just be wasting a LOT of fuel, and running VERY rich. however, you might find it most economical to buy the parts to upgrade system by system, rather than buying everything at once. But, i know its a killer when you have the parts, but not the time to install everything. Ideally, you should upgrade the fuel system AS you upgrade the turbos. As you know, air and fuel work hand in hand (unless your adding the juice....in which case you could just upgrade fuel...but really all that would be is a wet shot with an extra fuel line with the Nitrous line).
bonne chance!
93 3000GT base
K&N | long tube headers | 3sx crank pulley| testpipe | Addco front/rear sway bars (3SX) | rear strut bar & front 3-point strut bar (by JonVr4 on 3Si) | solid motor mounts | LSD insert | KYB GR-2 struts | intrax springs | adj. control arms | ss brake lines | 16% taller 5th gear (teamrip.com) | H4 conversion | push-button start | datalogger | HKS S-AFR | PLX WB O2
coming soon: adj. cam gears | bi-xenon HID retrofit
Old 12-13-2004, 01:40 PM
or what u could do is buy the fuel upgrades and tune them to work with what u have and then retune once u upgrade but it would be smarter to just do it all at once
Old 12-13-2004, 02:09 PM
Thourun's Avatar
Re: New tunable MAF
How far can you boost on 93 octaine?
1995 3000GT VR-4
Old 12-13-2004, 02:38 PM
Igovert500's Avatar
blue + red light magnet
Re: New tunable MAF
Gotta run to my final, so I'll check this out more at a later time, but it has gotten my interest.
One thing I noticed...that thing about no oil, as it clogs the sensors...as far as I know, that is only a rumor, never been proven.
I will have to read the reviews on 3si later, because I really am interested.
As far as boosting on 93 octane..with upgraded turbos and fuel systems, you should get a datalogger to monitor knock and everything else. General estimates with that much power could be deadly if the weather changes.
And personally, I wouldn't upgrade the fuel system until the turbos. Do it all at the same time.
96 3000gt vr4
-K&N FIPK
-Proboost mbc
-Greddy type-s
-ATR downpipe
-no cats
Old 12-13-2004, 11:24 PM
Igovert500's Avatar
Re: New tunable MAF
Wow, I just read all 16 pages...
I have to say it peaked my interest. I'm definantly considering it in the future instead of the LS6 Maft. I think there are valid arguments on both sides...which makes it tough...
I was completely sold until Jeff Lucius posted. But I think overall driveability throughout the range, plus the ease of installation and tuning are going to swing me. Very good find Thourun, Thanks.
96 3000gt vr4
-K&N FIPK
-Proboost mbc
-Greddy type-s
-ATR downpipe
-no cats
Old 12-14-2004, 07:44 AM
Thourun's Avatar
Re: New tunable MAF
Yea I thought you especially mignt be interested.
1995 3000GT VR-4
Old 12-14-2004, 09:06 AM
well when i first looked at this thread i didn't read the link just chimmed in about the fuel situation but now i read it and was wondering if anyone knew if this would work on an sl?
Old 12-14-2004, 01:27 PM
Igovert500's Avatar
Re: New tunable MAF
It's not worth it for an SL...unless you are heavily modded. It's benefits are negligable on stock vr4s. It only becomes really worth it with larger injectors and larger turbos.
96 3000gt vr4
-K&N FIPK
-Proboost mbc
-Greddy type-s
-ATR downpipe
-no cats
