Old 12-13-2004, 04:06 AM
Countrygalnlv Countrygalnlv is offline
Question Starts on and off
I have an 1989 cherokee straight 6 4.0 last couple weeks has been giveing me troubles starting pop the hood wiggle the plug wires and make sure they are all tight and it starts so we changed all the plugs but still haveing a problem then yesterday hooked it up to a battery charger started right up.
My plan today is to change the plug wires, cap, roter, thermostat(was over heating took thermostat out a month or so ago and just got a new one), and battery.
I need to know if this doesnt work what my other possible problems can be. As detialed as possible since I have no choice but to do the work myself liveing over seas and the mechnics pices are outragious (eg: $3000.00) to change rear main seal.
Thanks
Old 12-13-2004, 09:11 AM
Saudade's Avatar
Saudade Saudade is offline
Re: Starts on and off
Once it starts, does it run OK? Once it's hot, does it start right up? If it doesn't start on it's own, does it start with a jump (besides the time you posted)?
Changing the rear main seal is not too difficult (just messy). I did mine in my garage with just a few hand tools.
http://jeepin.com/features/rearmain/index.asp
Old 12-13-2004, 09:13 AM
Once it starts it runs fine, there is no real specific time when it wont start hot vs. cold and it always turns over but will not start and has never had to be jumped except the time we put it on the charger.
Old 12-13-2004, 09:18 AM
Also can someone tell me does the 1989 chrokee have points? I was told yes but cant find them in the chiliton manual
Old 12-13-2004, 01:11 PM
Saudade's Avatar
It does not. It's electronic ignition and electronic fule injection. It's important to determine if, when it doesn't start, is it a fuel problem or an electrical problem.
There are a number of sensors that control both ignition and fuel delivery. A common problem is a failing Crankshaft Position Sensor (CPS). If it's bad or intermittent, it would prevent the car from starting (no spark) but would also cause the engine to quit when running.
On my '88, I found a number of connectors to these sensors that had some corrosion. You may want to disconnect them to inspect them and clean as needed.
Old 12-13-2004, 02:39 PM
I doubt its a fuel problem about 2-2.5 yrs ago I replaced all fule injectors, fule pump, fule presure regulator, and fule filter I dont think theres anything left of the fuel system.
I hasnt quit running only problem is wont start cold or warm doesnt matter it starts when it wants to.
Old 12-13-2004, 03:16 PM
Dale Aeppli Dale Aeppli is offline
Re: Re: Starts on and off
Can you hear the fuel pump click when you turn key on. Try turning key on and waiting 15-30 seconds and then try starting. If it starts this way the fuel pressure is leaking and looseing prime. dale
[email protected]
Old 12-14-2004, 04:15 AM
Ok so I changed the plug wires, cap, and rotator, put a new battery in it and still nothing. Do fule pumps really go bad taht fast?
Old 12-14-2004, 12:54 PM
Saudade's Avatar
Are you getting spark at the plugs? Also, put a fuel pressure gauge on the port on the fuel rail and see what pressure you get with the key on (not running).
Also try the other "usual suspects". Move the shifter around to see if it's a bad Neutral Safety Switch.
Old 12-14-2004, 10:20 PM
Ironic Ironic is offline
You mentioned that it overheated, having the 89 as you do I know how them "expansion" bottles manage to spray all over the place. If the problem is intermitant- clean up any electrical connecters that are within reach. If the engine cranks you ruled out the starter, and neutral safty switch. If it cranks but won't start determine whether you have spark and fuel.
Old 12-15-2004, 01:24 AM
OK Im pretty sure now that it is the fule pump since I no longer here that nice hum the fule pump makes when the key is in the start position. Now my question is, is it possible that its a fues??? Please tell me its possible its a fues because I hate the though of changeing that pump again. If it is a fues can someone tell me which fuse box its in? I read the chilton but it doesnt mention a fuse for fuel pump.
Thanks
Old 12-15-2004, 02:42 AM
89ltd 89ltd is offline
on the passenger side there are four relays, the fuel pump relay is the third from the fire wall. You could try that, also, power going to the relay is supplied from the starter relay through a fusable link
Old 12-15-2004, 07:12 AM
Great!! thanks!! Sounds so much easier than changeing the damn fuel pump again. That was a major pain.
